Led Blink Rate?
Posted 21 February 2012 - 04:46 AM
I know when my battery is low it's on solid, so it would seem the phone has the ability.
Posted 21 February 2012 - 04:57 AM
#3 Guest_jmonroe0914_*
Posted 02 March 2012 - 09:24 PM
Droid RAZR MAXX
Posted 03 March 2012 - 04:31 PM
Light Flow Lite does allow you to alter the the sequence of blinks for the LED. it allows you to change it form super slow to super fast and everything in between, as well as stay solid.
Droid RAZR MAXX
Does it actually work for you? Because it seems it doesn't for the rest of us. I suggest you go into the app and mess with those settings and test it out for yourself if you haven't already.
Posted 04 March 2012 - 02:12 AM
The one problem I see right now... phone has been off charger for 40 minutes. Light Flow shows as using 51% of the battery. I'm going to play with if for a while and see what happens. If this app turns out to be a phone drain, I'd rather deal with a blinking LED than a dead battery. I'll post an update later after I've had a chance to experiment more.
I had a profile set to keep the LED on solid when the battery charged to 100%. I'll turn that off and see if it makes a difference.
Posted 04 March 2012 - 09:56 AM
#7 Guest_jmonroe0914_*
Posted 05 March 2012 - 01:58 PM
Ya, it works perfectly fine for me. I've had it working on both the RAZR since November, and the RAZR MAXX since January.
Posted 05 March 2012 - 02:07 PM
:-D :-D
Posted 05 March 2012 - 03:29 PM
I use this app also. If it's draining the battery it's probably not the LED itself it's probably the app. LEDs are pretty efficient.Yeah it makes sense that having the LED constantly on after a notification would kill the Razrs battery quick. Cool idea though.
Posted 06 March 2012 - 05:27 AM
Posted 06 March 2012 - 06:52 PM
Posted 06 March 2012 - 08:56 PM
Posted 13 March 2012 - 11:06 AM
Posted 24 May 2012 - 08:09 AM
