XT912 Grey Wifi Bars
Posted 22 February 2013 - 01:14 AM
Posted 22 February 2013 - 01:23 AM
Posted 22 February 2013 - 01:28 AM
Can't download anything due to the fact I cannot access google play or the web browser.Try this app
Posted 22 February 2013 - 01:51 AM
Ah OK. Sorry about that. Didn't know that you only had wifi and no data connection. I am uploading the apk to my dropbox so you can download it on your computer then transfer it to your phone and install.
Posted 22 February 2013 - 01:53 AM
Posted 22 February 2013 - 01:59 AM
Okay so I've installed the app and hit "Fix wifi connection" but no dice. Still got grey bars and cannot connect to anything.Pm sent. Its a free app so its not piracy btw. Once you get it on your phone just use a file explorer to find and install it.
Posted 22 February 2013 - 02:18 AM
Posted 22 February 2013 - 02:29 AM
Yes wifi worked before and the only change was root and no I factory reset my phone so no apps forcing wifi to run. By the way is there a way I can reflash the OTA JB leak? maybe that can work.Have you rebooted the phone lately? Did wifi work before? Any changes to the phone if wifi has previously worked? Any apps installed that force wifi to run?
Posted 22 February 2013 - 02:52 AM
Use the unbrick utility in this link.
JB OTA update How To's, With Details for Begininers
That will let you reflash the JB leak
Posted 22 February 2013 - 03:07 AM
Any JB unbrick utility for mac?Use the unbrick utility in this link.
Posted 22 February 2013 - 07:15 AM
Not sure you actually need Unbrick though....not enough info in your thread.
Are you ICS? sine you ask about the OTA update I assume you are ICS still. In which case you should run 1.82 for Mac and then update to JB.
Jump into chatroom for faster service
Posted 22 February 2013 - 11:10 AM
I'm not sure this will work...but...I figure with the situation you are in, that it's worth a shot. Unroot your phone. You should be able to remove Superuser, or even bertter SuperSU, will totally unroot your phone without going into a file explorer and deleting your copy of su. Factory reset your phone, wipe cache, dalvik cache and reinstall the JB OTA, using the Motorola recovery in the phone. I know that this won't fix some problems but I'd try it. I did it when I was messing around with triying to use the sideload option now available with the JB update. I'm by no means an authority on anything android and I don't know what was reinstalled dong that. If not, then using the unbrick utility will fool the update into reinstalling the update giving you stock JB Razr and then you can reroot with the blade root utility
Posted 22 February 2013 - 07:47 PM
Posted 22 February 2013 - 08:38 PM
Posted 22 February 2013 - 10:47 PM
Posted 25 February 2013 - 12:33 PM
