[Theme] Transformx For Razrx 1.2
Posted 21 February 2012 - 12:05 PM
This is a theme I did for DroidX and ported to the Razr. It still needs some touch-ups here and there but wil fix in future updates.
I used some elements from my Razrs Blue Edge theme to fill in the gaps.
I am not responsible for what you do to your phone!!! You assume all risks involved. I have tested all these themes and I had no issues.
Thanks goes out to skiwong20 and DroidTh3ory for the work they put into developing RazrX and for what I used from the rom to make this theme.
Thanks to Bignadad for using one of his install scripts.
10.78KB 35 downloads 13.55KB 37 downloads 24.94KB 26 downloads 16.96KB 16 downloads 25.55KB 14 downloads
Install Instructions:
Make sure you on RazrX 1.2 ,173 based rom
(Recomended) Make a backup in recovery and reboot (always a good ideal before flashing anything) and have enough juice in case something goes wrong
Download the theme and place it on your sd-ext (not internal memory)
Reboot into recovery with Razr bootstrap
select choose zip from sd card and navigate to where theme is
select theme and confirm selection again.
When theme has finished installing go back and reboot
Enjoy!!!
Razr X 1.2
TransformX - no longer supported
Posted 21 February 2012 - 12:07 PM
14.79KB 11 downloads
Posted 21 February 2012 - 12:16 PM
8.01KB 13 downloads
Posted 21 February 2012 - 01:48 PM
I thought about it, if enough ppl are interested I might.So you going to do a bumble bee and megatron ?
- fastfoodfred likes this
Posted 21 February 2012 - 01:59 PM
-Grand Master of the Testing-
#7 Guest_24v_*
Posted 21 February 2012 - 02:11 PM
Posted 21 February 2012 - 02:16 PM
Here's a theme I did for DroidX and thought I would port it. What you think, keep going with this?
This theme will be nice for any NY Giants fans Seriously though, nice work Wulf! IMO, the more themes, roms, mods, etc that are available, the better. Keep up the good work!
Posted 21 February 2012 - 08:42 PM
Thanks, still some touchups here and there but still very usable. I might post it as is and just update it. Had some time to do some ports from my past themes.this looks awesome wulf!
Posted 21 February 2012 - 10:08 PM
Posted 21 February 2012 - 10:17 PM
Yeah, I loved the cartoon and the movies.Love it! The nostalgic kids in me still watches Transformers and GI Joe on Hub.
Going to post it in a few, bugs will be fixed in future updates if you find some.
Posted 21 February 2012 - 10:25 PM
Posted 01 March 2012 - 07:34 PM
Posted 01 March 2012 - 07:55 PM
Lol, theme was originally for the DROIDX and screen wasn't as vivid as the razr and didn't look as bright. I would have to redo all the images to go with razr display.i like it but the colors are too bright with brightness turned all the way down. It hurts my eyes
Probably wont update theme since not much interest in it,lol.
Posted 01 March 2012 - 07:59 PM
thanks for the reply, im kinda sad inside now lol razrx is one of the better roms lol how come derazrx never got any sweet themes? its deo....
Posted 01 March 2012 - 08:34 PM
If I get some free time i might do some edits and use it myself since it was one of my favorites on the droid X and will share it if I update it but wont be anytime soon.
Derarx was still on .148 and I dont think it ever got updated for 173.
Posted 01 March 2012 - 08:41 PM
all 748 roms are good to use on 173. bluetooth will just be broke. Deo on 173 base is extremely hard to do hence the reason abysm and derazrx are not updated to the 173 base. Its y if you ever noticed that eclipse is the only "true" deo rom on the 173 base.....
Posted 01 March 2012 - 08:52 PM
Good to know, I havent tried any 148 roms on 173. I need bluetooth to work, lol. I noticed eclipse and I see Artic getting updated for 173. I use to many blur apps to use them but I have tried eclipse and its a good rom.all 748 roms are good to use on 173. bluetooth will just be broke. Deo on 173 base is extremely hard to do hence the reason abysm and derazrx are not updated to the 173 base. Its y if you ever noticed that eclipse is the only "true" deo rom on the 173 base.....
Posted 01 March 2012 - 09:06 PM
Artic is a gsm rom ported over to cdma and is actually a 748 base with a bluetooth fix for 173..... me and matt have talked about it
