Hey guys, just start installing roms last week and i have 3 in safe strap but i'm almost out of room... plugged my bionic into my pc and went through the internal folders to see what was taking up all the space. safestrap is taking up like 5.6gigs. is there any way to move this folder to the sd card without causing any harm at all? i need to free up some space because i keep getting that low on volume space notification. What can i do? Thanks!
running out of room
kdrumz16
, Feb 23 2013 02:16 PM
6 replies to this topic
Posted 23 February 2013 - 02:16 PM
Posted 23 February 2013 - 03:53 PM
You could always wipe internal and start over or ditch a rom slot.
Posted 23 February 2013 - 04:33 PM
what about moving safestrap to my external sd?
Posted 23 February 2013 - 05:10 PM
Roms running on safestrap slots can only be accessed if in the internal storage. The different read and write speeds if sdcards can leave a rom unstable if running from the sdcard. Especially blur based roms. Unfortunately you might have to delete your third rom slot to avoid the low storage message. I could only run 2 rom slots plus the stock rom at a time.
Posted 17 March 2013 - 05:32 PM
Moved to Droid Bionic General Reason: Non-Emergency situation.
Posted 17 March 2013 - 08:31 PM
i can only run 3 and only 1gb for data but i only run a few standard apps on all roms . normally i run only slot 1 with 3gbs and just backup and restore like bootstrap ,,,, but since we have all these jb rom choices i have slimmed down and spread out so i can flash all the nightlies and have 4 roms , inc. stock , its what safestrap is made for aye .
- nrvusinergy likes this
TEXAS state of mind
Posted 04 April 2013 - 09:36 AM
Is there anyway to bypass safestrap slots completely? Even when I only have one slot, I still face annoying size constraints.
