stock razr m ringtones and notifcation sounds
Posted 23 February 2013 - 06:15 PM
Posted 23 February 2013 - 08:33 PM
Razr M Wallpapers -
Razr HD Sounds (I do believe Hd and M are the same phone but different sizing so try these i pulled from a stock rom) -
THE ZIP IS NOT FLASHABLE ITS JUST A ZIP OF THE SOUNDS IF YOU WANT TO COPY AND USE THEM
hope this helps
Posted 23 February 2013 - 08:38 PM
Posted 23 February 2013 - 08:42 PM
no sorry that isnt flashable, pretty sure on cm10 if you want to use one as a ringtone you can hold down on it on a file explorer and i think it would say set as. if not than use root browser lite and copy the ringtones in the folder into system-> Media -> and ringtone (or) noticifationthanks so much so i wouldn't have to flash any of that stuff? just transfer to sd from stock rom?
Posted 23 February 2013 - 08:49 PM
Posted 23 February 2013 - 08:53 PM
Posted 23 February 2013 - 09:02 PM
Posted 23 February 2013 - 09:03 PM
Posted 23 February 2013 - 09:07 PM
yeah it would need a reboot tell me if it works
edit: not to give a dumb answer but did you make sure the volume is up? like media volume or ringtone, etc?
yea haha the other ringtones work fine
Posted 23 February 2013 - 09:10 PM
so it worked?
no the ringtones that came on cm10 work just not that one i added to the list
Posted 23 February 2013 - 09:16 PM
Posted 23 February 2013 - 09:21 PM
Posted 23 February 2013 - 09:28 PM
