Selective Notifications Help?
Posted 22 February 2012 - 05:57 AM
Is there a way to differentiate between notifications for emails and text messages? I've seen you can turn off notifications for specific email accounts, but I'm not sure if that only defeats the sound (for emails) or everything.
Ideally, I'd like the phone to play a sound when I get a text, and either play a different sound or maybe no sound when I get an email.
Thanks.
Posted 22 February 2012 - 02:28 PM
Posted 22 February 2012 - 02:33 PM
For the regular email app that should be under settings as well. Most apps like that give you an option in the settings to alter the notification from default settings.
Sent from my AOKP AXI0M[R]
Posted 29 February 2012 - 10:57 AM
Posted 29 February 2012 - 02:46 PM
Another option is to look at getting different apps for SMS and email. I use GO SMS Pro (which requires GO Launcher, both free) for messages, and it allows custom settings for both notification sound and LED. I just started using K-9 email and while it allows custom notification sounds, it doesn't appear to use the LED at all, which I don't like. Anyway, trying different apps from the Android Market is another way to go.
Go SMS does not require go launcher. You can use it with any launcher with or without go launcher isntalled.
Also, check out light flow. It's for root users but it works. And it has a lot of options as far as notifications go. There is a free version as well as a paid one.
Sent from my AOKP AXI0M [R]
Posted 05 March 2012 - 08:23 PM
