Help! most annoying issue....
Posted 25 February 2013 - 08:29 AM
My notification LED is constantly blinking green....even when i have no emails,texts, etc.
I can sometimes get it to go away for a short period of time when I turn airplane mode on and off again... but now its getting harder and harder to make it stop.
I do have my phone on silent a lot so I do rely on the notifications LED...
Any help?
Posted 25 February 2013 - 02:09 PM
Posted 25 February 2013 - 02:41 PM
Posted 25 February 2013 - 02:51 PM
Posted 26 February 2013 - 05:05 AM
nothing newly installed except Battery Guru by Qualcomm...Hmm... Any newly installed apps?? Maybe try installing lightflow and see if that helps. I did a quick google search but couldn't find anything helpful or than a rogue app.
Matt has a JB unbrick util… still, I think Fix Permissions will help…
i'm lost - why an unbrick tool?
Posted 26 February 2013 - 05:30 AM
admittedly, it is an unexpected approach, but this is a thorny problem. I'll reiterate my oter suggestion of Fix Permissions.
Yes - you'll have to install SS, but the 3xx version is so much faster & will also give you the ability to make nand backups (also faster than SS 2xx) & give you tools to help w/probs as well like wiping cache &/or dalvik & Fix Permissions…
Good luck!
Posted 26 February 2013 - 06:41 AM
Posted 11 March 2013 - 07:13 PM
notification light widget @ playstore by Motorola Mobility free
mine blinked all the time also just turn the stupid thing off
