Where can i get a copy of this apk because i flashed artic rom and lost my madden app that came with stock rom. Anyone have the apk or how can i get ahold of a copy of it.
Madden 12
starscreamxb
, Feb 22 2012 09:56 PM
1 reply to this topic
Posted 22 February 2012 - 09:56 PM
Posted 26 February 2012 - 07:44 PM
If you have root explorer go to the internal memory and search for a folder called "preinstall/app" The madden file should be in there, you just have to add the ".apk" to the filename so you can install it. If you can't find it ill see if I can upload an apk for you.
