Rom Tool Kit And Matt's Razrutility
Posted 23 February 2012 - 10:45 AM
Posted 23 February 2012 - 10:46 AM
:-D :-D
Posted 23 February 2012 - 11:00 AM
Never use bootstrap with safestrap. Always remove one or the other as specified in their OP's
As for the other two. I'm not qualified to answer that..
I don't see why there would be an issue.
Both use zergrush exploite right ?
Posted 23 February 2012 - 11:04 AM
Why do you want either of them?
When I read this by DirtyDroidX, I asked about uninstalling Bootstrap Recovery in the How To Section:
ROM Toolbox Pro hands down is the best utility IMO. Now what I do is make a backup of every stock system when I first load it up . That is for a last resort, will explain later. In my research and personal use TBU does not play nice with the RAZR. I also backup all system apps in ROM toolbox. I always back them up to SD-ext. Now I no what system apps can go and what needs to stay. If your new I suggest freezing them or renaming them .bak until you no that your phone will work 100%. Now as my last resort say you fubared your phone so bad deleated stuff you dud not realize you where going to need etc etc. When you make a backup of your stock system, keep a copy on your PC or a flash drive. Now if you are in thus situation you can use appextractor from the market and restore files from a backup!
NOTE+++ when you are on a different ROM and you restore your apps and DATA, there is a good chance most of them won't work, or they will force close, or just blow your phone up
Based on the above, why wouldn't we want ROM Toolbox Pro?
Posted 23 February 2012 - 11:15 AM
Thanks for the response. I want to be able to flash ROMs at some point. If all I need is Matt's Utility to do that that's fine. And, I want to be able to safely and quickly return to stock if need be...Matt's utility seems to provide that option when needed. I've read here that ROM Tool Box is a must for anyone who has root but I've also seen post touting ROM Manager, which seems to be a duplication of capability and apps. Does that clarify my questions?Why do you want either of them?
Posted 23 February 2012 - 11:23 AM
He didn't mention ROM Toolbox. I use ROM Toolbox just about every day.
SafeStrap or Bootstrap is what you actually use to flash ROMs, the utility doesn't have anything to do with it. It just makes the preparation for flashing a bit easier.
My recommendation is to install SafeStrap and flash ROMs that way, there are instructions for use all over the place; or you can jump into the chat and ask there.
:-D :-D
Posted 23 February 2012 - 11:28 AM
I've got the instruction for SafeStrap and understand them. Would you recommend keeping ROM Tool Kit?He didn't mention ROM Toolbox. I use ROM Toolbox just about every day.
Posted 23 February 2012 - 11:29 AM
:-D :-D
Posted 23 February 2012 - 11:40 AM
Opps...I meant ROM Toolbox (Pro)...thanks for your help.No. The only other root utility you need is ROM Toolbox (Pro). It is basically every other root/ROM app bundled into one giant super-utility.
Posted 23 February 2012 - 11:42 AM
Just make sure that you don't use RTb to flash ROMs, use SafeStrap.
:-D :-D
Posted 23 February 2012 - 12:00 PM
Yeah, a noob "thing". Can't keep all these apps and what they're used for straight.Oh I see, that's where the confusion came from; there is another app called ROM Toolkit.
Posted 23 February 2012 - 04:54 PM
I also took for granted he was referring to ROM Toolbox..............
Techno: you mind elaborating on your reasons for not using ROM Toolbox Pro for flashing ROMs? I was thinking that was one of it's "primary" functions. Have to do with the Razr's locked b/l?
Thanks for your insight.......
Posted 26 February 2012 - 06:25 PM
Posted 26 February 2012 - 10:07 PM
I don't want to give you bad info so I'm not going to tell you why, but I'm pretty sure the bootloader is a major part of it.
:-D :-D
