I am playing Order and Chaos on my Droid Razr with mutlisample anti-aliasing at 1.4ghz.
***UPDATED! Safe with no problems as far as I can tell.***
1. Find the file build.prop in /system. You will need root access and a file manager like ES File explorer to edit this file. Open the file in any text editor and change this value. ***If you are having trouble at this point google how to edit build.prop file or something...**
ro.product.model=DROID3
Then Reboot
2. Download the APK and install it.
3. Once you have your game installed and working properly (make sure you have ran the game and downloaded any additional data required to play), open your build.prop file one more time and change the value back.
ro.product.model=DROID RAZR
Reboot again.
Game and phone should now work fine. This should work on all games with compatibility issues.
This is not my brain child. This information is all over the internet, but it is not applied directly to this game.
Please feel free to ask any questions.
To overclock your razr go to
(this is not required for the Order and Chaos fix).
To enable Multisample anti-aliasing you need the pro version of Chainfire3d.
(not required for the Order and Chaos fix).
Order And Chaos Working On Droid Razr
sublimerocks13
, Feb 23 2012 03:50 PM
No replies to this topic
