Ss3.12
Posted 26 February 2013 - 07:41 PM
Posted 26 February 2013 - 09:06 PM
Posted 27 February 2013 - 11:05 PM
I have ss3.12 how would I go about updating to the newest version?
3.12 is the newest version indeed... but if there was to be a new version all you have to do is uninstall recovery than uninstall app... than install the newer one and install recovery once again.. rebootIs 3.12 not the latest version?
Posted 27 February 2013 - 11:28 PM
Now, if I had to do this, it would be from my stock ROM slot? I would assume that deleting SS would also delete my custom ROM, and I would have to reinstall ROM after re-flashing the newest version of SS? I tried to find a clear-cut answer on this but couldn't find any definite answer.3.12 is the newest version indeed... but if there was to be a new version all you have to do is uninstall recovery than uninstall app... than install the newer one and install recovery once again.. reboot
Posted 28 February 2013 - 03:18 AM
Works perfectly for me & I've never had an issue.
Posted 28 February 2013 - 08:29 AM
Posted 05 March 2013 - 07:49 AM
