[Theme] Blue Edge For Stock 173
Posted 23 February 2012 - 08:14 PM
369.29KB 90 downloads 131.27KB 99 downloads 190.67KB 78 downloads 56.58KB 60 downloads
97.42KB 52 downloads 118.04KB 45 downloads 119.4KB 42 downloads 56.29KB 34 downloads
Install Instructions:
Make sure you on stock173
(Recomended) Make a backup in recovery and reboot (always a good ideal before flashing anything) and have enough juice in case something goes wrong
Download the theme and place it on your sd-ext (not internal memory)
Reboot into recovery with Razr bootstrap
select choose zip from sd card and navigate to where theme is
select theme and confirm selection again.
When theme has finished installing go back and reboot
Enjoy!!!
I also made a revert to stock zip you can flash. You can use it to remove a theme for stock or if you have issues.
NOTE:If you lose settings for any reason flash the revert to stock zip, reboot then flash theme, should be good after that.
Blue Edge - no longer supported
(updated 2-28-12))
Revert to 173 Stock - no longer supported
- listenman20 likes this
#2 Guest_24v_*
Posted 24 February 2012 - 03:48 AM
Posted 24 February 2012 - 04:06 AM
Posted 24 February 2012 - 02:31 PM
Any green in your forecast???
Posted 24 February 2012 - 02:40 PM
I do see a green glow in the distance, lol.
I did do one for older version of RazrX. I just need to update it for stock.
Posted 24 February 2012 - 03:05 PM
- dustincook87 likes this
Posted 24 February 2012 - 06:08 PM
Download and flash the revert to stock zip in OP, youll get settings back. Then reflash theme and it should be good after that.Anyone else having an issue with the settings menu not showing up. It force closes on stock launcher and on spd shell its no where to be found. This is happening on all of wulf themes.
Posted 24 February 2012 - 06:55 PM
Posted 24 February 2012 - 07:08 PM
Glad you got it.Its there now. Thanks!!!
There is a possibility you might lose settings if you make a backup before flashing theme, restore a backup before flashing theme or if you flash one theme over another. This could be because of settings being inverted.
Posted 26 February 2012 - 02:41 PM
I ported Razrs Blue Edge theme for stock 173. I will port the other colors and maybe a new color.
369.29KB 90 downloads 131.27KB 99 downloads 190.67KB 78 downloads 56.58KB 60 downloads 97.42KB 52 downloads 118.04KB 45 downloads 119.4KB 42 downloads 56.29KB 34 downloads Install Instructions: Make sure you on stock173 (Recomended) Make a backup in recovery and reboot (always a good ideal before flashing anything) and have enough juice in case something goes wrong Download the theme and place it on your sd-ext (not internal memory) Reboot into recovery with Razr bootstrap select choose zip from sd card and navigate to where theme is select theme and confirm selection again. When theme has finished installing go back and reboot Enjoy!!! I also made a revert to stock zip you can flash. You can use it to remove a theme for stock or if you have issues. NOTE:If you lose settings for any reason flash the revert to stock zip, reboot then flash theme, should be good after that. Blue Edge - Revert to 173 Stock - Not expected but if you like you can donate
can you do this with safestrap??
Posted 26 February 2012 - 02:46 PM
I've always used bootstrap, but some ppl said they've used safe strap.can you do this with safestrap??
Maybe someone that uses safestrap can answer this.
Posted 26 February 2012 - 02:51 PM
can i just delete safestrap then install bootstrap from matt's utility? i had bootstrap installed once and deleteted it
Posted 26 February 2012 - 03:19 PM
I don't know much about safestap and cannot answer this with any certainty, sorry about that.can i just delete safestrap then install bootstrap from matt's utility? i had bootstrap installed once and deleteted it
Posted 26 February 2012 - 04:02 PM
Posted 26 February 2012 - 04:06 PM
What parts from spiderman theme are still there? I have all the stock apks just let me know which ones and I'll include them in the revert to stock zip.I know have settings back but i have a new problem. I flashed the Spiderman theme to see if it had settings and it did. But after flashing back to simply stock or blue edge there are still bits and pieces of the Spiderman theme left. I wiped cache 3x and davlic 3 x as well and I tries revert to stock. Still there.
Posted 26 February 2012 - 04:09 PM
Posted 26 February 2012 - 04:11 PM
Posted 26 February 2012 - 04:13 PM
Posted 26 February 2012 - 05:16 PM
Im uploading a new revert to 173 stock. I added more stock apks for good measure..My download icon is spidy. And stock calendar has some spidy image in the events area.
Posted 26 February 2012 - 05:19 PM
