[Theme] Violet Edge For Stock 173 And Razrx 1.2
Posted 25 February 2012 - 01:27 AM
361.29KB 21 downloads 130.58KB 24 downloads 190.06KB 26 downloads 55.68KB 22 downloads
96.92KB 16 downloads 118.1KB 7 downloads 107.82KB 7 downloads 79.83KB 6 downloads
398.97KB 5 downloads 315.13KB 3 downloads
Install Instructions:
Make sure you on correct ROM either Stock 173 or RazrX 1.2 and download right zip.
(Recomended) Make a backup in recovery and reboot (always a good ideal before flashing anything) and have enough juice in case something goes wrong
Download the theme and place it on your sd-ext (not internal memory)
Reboot into recovery with Razr bootstrap
select choose zip from sd card and navigate to where theme is
select theme and confirm selection again.
When theme has finished installing go back and reboot
Enjoy!!!
I also made a revert to stock zip you can flash. You can use it to remove a theme for stock or if you have issues.
NOTE:If you lose settings for any reason flash the revert to stock zip, reboot then flash theme, should be good after that.
Stock 173
Violet Edge theme for stock 173 - no longer supported
(updated 2-28-12))
Revert to stock 173 - no longer supported
RazrX 1.2
Razrs VioletEdge for RazrX 1.2 - no longer supported
Revert to Stock RazrX 1.2 - no longer supported
- raijin32 and dustincook87 like this
Posted 25 February 2012 - 02:00 AM
Thanks. Lol, it would work great for that.I love this wulf goes perfect with minnesota vikings wallpaper.
Posted 25 February 2012 - 04:21 AM
Posted 25 February 2012 - 06:40 AM
This is for stock 173 and you only use the revert to stock if your on stock 173.since im on razrx v1.2 does that mean i should flash the revert to stock first?
I have one for RazrX but still needs to be tested.
Posted 25 February 2012 - 09:05 AM
Posted 26 February 2012 - 11:01 AM
Edit: flashed theme but my phone settings app is gone from app drawer and settings option in menu does not work. Will reboot and see what happens.
Edit2: Tried everything but my settings menu and app are gone. Very odd but i just cant use this theme without that. Looks great though.
Posted 26 February 2012 - 12:02 PM
If you flash revert to stock zip, reboot and flash theme after you should have settings back .Flashed back to 173 stock just for this theme. Downloading now so haven't seen it live yet but screen shots look great.
Posted 26 February 2012 - 12:35 PM
Posted 26 February 2012 - 12:44 PM
I plan on getting red, orange and maybe green over for stock 173.Really like these 173 stock color themes. Any chance of getting a red version?
- Rouger likes this
Posted 26 February 2012 - 12:50 PM
That's great news. Thanks for the hard work on these...
Posted 26 February 2012 - 02:13 PM
67.1KB 6 downloads 20.88KB 6 downloads 34.97KB 3 downloads 18.67KB 2 downloads
Posted 26 February 2012 - 04:31 PM
I flashed the revert earlier after not finding a fix and thought about trying a second flash but didn't do it....until now. Thanks. Worked like a charm the second time. Great theme.
Posted 26 February 2012 - 04:50 PM
Thanks. Good to see you got it.
Posted 26 February 2012 - 05:41 PM
Posted 15 March 2012 - 07:53 AM
Posted 16 March 2012 - 01:59 PM
I did a one a while back, have to find out where I put it. When I find it Ill make a flashable zip and post it in the OPThanks for the theme. It's beautiful. Is there any way to make the bootanimation go with this theme?make
Posted 19 March 2012 - 07:37 PM
Posted 19 March 2012 - 08:00 PM
And a big bad +1 here brother!Say Wulf... I love this theme of yours. However, is there any remote chance you could port the black N Bold theme? I am pretty sure many would love to have some BnB also. Cheers mate
Posted 19 March 2012 - 09:43 PM
I never did black N bold theme.Say Wulf... I love this theme of yours. However, is there any remote chance you could port the black N Bold theme? I am pretty sure many would love to have some BnB also. Cheers mate
