Is There Anyway To Get Rid Of Certain System Notifications?
Posted 25 February 2012 - 10:18 AM
Thanks in advance
Posted 27 February 2012 - 09:56 PM
Posted 28 February 2012 - 05:31 AM
Posted 29 February 2012 - 06:05 AM
I hate "low on volume space"! I know my SD card is full, I put the files on there! lol
Hahaha really tho. I can't stand it. Anybody got any ideas?
#6 Guest_24v_*
Posted 29 February 2012 - 02:33 PM
Posted 29 February 2012 - 05:45 PM
<br /><br />It doesn't really matter what it says. My main gripe is the icon in the status bar. Could that be removed or made transparent? And could you possibly tell me where these edits would be made?I think I can change it to something else for you. Just not sure you can remove it. If you want me to try changing it, tell me what you want it to say and I will give it a shot.
#8 Guest_24v_*
Posted 29 February 2012 - 05:57 PM
Yes,you can change the icon in the status bar. You would find it in /system/framework/framework-res.apk/res/drawable-hdpiIt doesn't really matter what it says. My main grip is the icon in the status bar. Could that be removed or made transparent? And could you possibly tell me where these edits would be made?
And to change the text you would look in /system/framework/framework-res.apk/res/values/strings.xml
I can fix the icon for you if you can give me a screenshot of what it looks like. I have never had that warning, and I am not running Eclipse so I want to make sure I fix the correct icon for you.
Posted 29 February 2012 - 06:38 PM
look at line 781 and 782 in strings...
<string name="low_internal_storage_view_title">Low on space</string>
<string name="low_internal_storage_view_text">Phone storage space is getting low.</string>
Change:
<string name="low_internal_storage_view_title"> </string>
<string name="low_internal_storage_view_text"> </string> (spaces may not be necessary but it wont hurt)
Image is
Ill looking for the option 2 way
#10 Guest_24v_*
Posted 29 February 2012 - 06:42 PM
I'm not sure what you mean? I was just going to change the text in strings for that particular notification.Your going to run into a problem by editing it in styles....your going to end up changing ALL notifications.
*sorry forgot about this
Posted 29 February 2012 - 07:28 PM
Thanks guys.
24v I would gladly have you do it for me but I'd love to learn if possible.
Posted 29 February 2012 - 08:40 PM
Posted 28 August 2012 - 12:32 PM
Posted 15 October 2012 - 11:12 AM
