received razr hd this week, trying to root JB from scratch.
gone through Matt's utility 1.0 twice. both times all is good until i get to flashing the JB, after i get back to 0.7.2. i get this message when trying to apply from .zip on my sd card's root:
qe 1/1
Finding update package...
Opening update package...
Verifying update package...
Installing update...
Verifying current system...
assert failed:apply_patch_check("/system/bin/logwrapper". "23d23abf573e78e4bfe692fedf631ad1faa3179e". "4a63fec78956def045b442910a754fa640db8f5a".
E: Error in /tmp/sideload/package.zip
(status 7)
Installation aborted.
thought it was a checksum error. did evrything all ovr again, downloaded new files... same results.
suggestions?
new problem with flashing JB
Jaded
, Mar 03 2013 12:55 PM
5 replies to this topic
Posted 03 March 2013 - 12:55 PM
Posted 03 March 2013 - 09:36 PM
Did you check the hash of the file you downloaded to ensure the Jelly Bean file downloaded correctly?
Posted 03 March 2013 - 09:41 PM
Try a factory data reset before applying the jb update.
Posted 04 March 2013 - 04:08 AM
Sounds like Safestrap is not Unloaded, also at the end of Matts utility did you select 1 to clear cache etc etc.. Like tmy said, factory reset, clear cache etc.
Posted 04 March 2013 - 06:39 AM
thanks for the new directions, back to the drawing board
edit: we have liftoff!
Posted 07 March 2013 - 07:50 AM
yeah i'm with Tmyinc hard reset
Do it now you may not be able to later
