Lockscreen and DPI change...
timpohladthomas
, Mar 04 2013 04:59 AM
5 replies to this topic
Posted 04 March 2013 - 06:24 AM
I don't think there is any fix for this. Changing the DPI is like changing the resolution on your PC. Things will move around as they are set up for the other resolution.
Posted 04 March 2013 - 06:39 AM
Hmm... there has to be some kind of changes/differences to the way Moto sets up the lockscreen to adapt to different screen sizes. Maybe touch base with a Dev here and ask them to look into it. I imagine it would be quite a task to compare both files and find the difference. Even if they did it may still be the way the lockscreen is programmed and not just as easy as changing one variable.
Posted 04 March 2013 - 07:43 PM
Hey, how did you get the white line off lockscreen under date??? Framework-res? or?Anybody got any help/suggestions for this?
