Need Help Possible Brick?
Posted 27 February 2012 - 07:11 PM
Posted 27 February 2012 - 07:23 PM
Posted 27 February 2012 - 07:42 PM
Blasted with my AOKP AXI0M[R]
Posted 27 February 2012 - 08:10 PM
Posted 27 February 2012 - 08:12 PM
Thach tried youre suggested method again and it worked thanks for the replies guys
Good deal, glad ya got it working.
Posted 27 February 2012 - 08:14 PM
Posted 27 February 2012 - 08:28 PM
After doing a fast boot try immediately doing a factory reset as well. I have always done these steps an have had no issues going stock.
Thach does a factory reset hit your internal sd card as well?
Posted 27 February 2012 - 08:30 PM
Factory reset wipes the /Data and /Cache partitions from the internal, so partially yes but not the full card.
Posted 27 February 2012 - 08:34 PM
Got it. Thanks Snives!
In other words nothing really important. It won't hurt any of your files. Cache files are easily rebuilt by the phone.
Stuff you've downloaded yourself or put there will stay there.
Sent from my AOKP AXI0M[R]
Posted 27 February 2012 - 08:35 PM
Depends what you call important. That includes app data.
Posted 27 February 2012 - 08:36 PM
Exactly what I wanted to hear. Thanks guys!!
Aww crap.. lol!!
Posted 27 February 2012 - 08:40 PM
Exactly. I have never lost anything important from my internal SD card when I have done this. When I first got the RAZR and came to the site, I was helping Bignadad test a theme and had to fast boot/factory reset 4 times in a row one night. But was up and running again in no time with nothing missing from my internal SD card that I needed.
Posted 27 February 2012 - 08:50 PM
Like Thach said..Exactly. I have never lost anything important from my internal SD card when I have done this. When I first got the RAZR and came to the site, I was helping Bignadad test a theme and had to fast boot/factory reset 4 times in a row one night. But was up and running again in no time with nothing missing from my internal SD card that I needed.
Not on the internal SD. Which if I'm understanding right is what raijin is worried about.
App data is in /data not /sdcard.
If you do a factory yes you will have to redownload/restore apps and set them up. But you won't lose things like pictures, songs, etc.
Posted 27 February 2012 - 08:52 PM
Like Thach said..
Is it the equivalent of restoring apps via TiBu minus the data restore?
Posted 27 February 2012 - 08:58 PM
Yep. You're just missing the apps and your set up. Takes a little time but an easy fix.
