Reboot in recover mode problems...
3 replies to this topic
#1 rastakull
rastakull
Posted 05 March 2013 - 12:57 AM
Ok, i'm a semi noob and trying to update to Cyanogen Mod 10 Jellybean 4.1.2 firmware... I've followed all the steps listed but when I get into recovery mode, the directions say to select "install zip from sd card" i'm not getting the option to do so... When in recovery mode, the only options i have are:
reboot system now
apply update from external storage
apply update from ADB
wipe date/factory reset
wipe cache partition
Any suggestions or explanations of what i'm doing wrong would be greatly appreciated!
#2 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 05 March 2013 - 01:00 AM
reboot system now
You need to Root your phone and use Safestrap, not Motorola Stock Recovery.
#3 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 05 March 2013 - 01:04 AM
Are you rooted and running SafeStrap? The options shown are the factory recovery program. The M does not have an unlocked bootloader, unless you have the dev model and have unlocked the bootloader. If you try to install CM through factory recovery, it won't work and will probably turn your phone into a paperweight. The "apply update from external storage" applies to factory updates only.
#4 rastakull
rastakull
Posted 05 March 2013 - 01:07 AM
I am Rooted but not sur ehow to use Safestrap... Googling now.... Thanks!
