[Theme] Green Edge For Stock 173
Posted 28 February 2012 - 10:52 PM
370.19KB 22 downloads 136.92KB 21 downloads 167.93KB 19 downloads 88.02KB 16 downloads
60.43KB 14 downloads 135.76KB 11 downloads 121.78KB 16 downloads 198.52KB 19 downloads
43.67KB 17 downloads 52.49KB 8 downloads
Install Instructions:
Make sure you on stock173
(Recomended) Make a backup in recovery and reboot (always a good ideal before flashing anything) and have enough juice in case something goes wrong
Download the theme and place it on your sd-ext (not internal memory)
Reboot into recovery with Razr bootstrap
select choose zip from sd card and navigate to where theme is
select theme and confirm selection again.
When theme has finished installing go back and reboot
Enjoy!!!
I also made a revert to stock zip you can flash. You can use it to remove a theme for stock or if you have issues.
NOTE:If you lose settings for any reason flash the revert to stock zip, reboot then flash theme, should be good after that.
Green Edge for Stock 173 - no longer supported
Revert to Stock 173 - no longer supported
Posted 01 March 2012 - 09:49 PM
68.35KB 11 downloads
Going to look around and see if anything else needs changing.
Posted 14 April 2012 - 05:37 PM
Posted 14 April 2012 - 06:12 PM
You know I think I forgot to upload the updated one, lol. Im uploading one I think has changes, you would have to flash it and let me know if it is cause cant test it right now.Mine doesnt have black letters on dropdown menu. Gonna reflash had settings problem. No biggie just asking?? How do u get black letters?
Edit: As far as losing settings download and flash the revert to stock zip, reboot and then go back and flash theme. That should take care of settings.
Posted 14 April 2012 - 08:38 PM
Posted 14 April 2012 - 11:02 PM
Cool, if you feel like trying it I think this has black text in pull down.Still white but dont trouble urself luving the red edge!
Posted 13 June 2012 - 04:43 AM
Sent from my DeathSCYTHE..
I'll see you in hell.. where the devil knows my name...
Posted 13 June 2012 - 05:23 AM
Dont know, I never use UOT. Give it a shot and let us know. Worse thing that can happen is a bootloopCan the pull down notifications be edited in UOT?
