[Help Wanted] MMS on Non-Verizon Carrier
Posted 06 March 2013 - 12:24 AM
I have an XT912 on Cellcom (it's a Wisconsin-based carrier). Basically, most things on the phone are similar to the Verizon version. I'm rooted, I have Safestrap working, and I'm able to run other ROMs just fine, as long as they use the ICS kernel. Unfortunately, I cannot flash the JB kernel, but that's not much of a problem for me. That's just some background information for anyone willing to try to help.
My only issue is that the MMS on my phone will not work when I'm not on the stock rom. I know on my previous phone (HTC Desire) there was a bit of work that went into getting the MMS to work on custom ROMs (such as CM, etc). For those of you who are experienced in these things, I'm wondering where would be a good place for me to start to try to get my MMS working on custom ROMs on the Razr MAXX? If I remember right, I can edit APNs, and I think I remember someone using a MMS.apk when they were getting MMS working on the HTC Desire. I should be able to dig up APN info for my carrier if anyone thinks I should start there. If I need a file from my stock ROM, just point me in the direction of the file and I'll dig it up. Again, I have root access, so that shouldn't be a problem.
If anyone's willing to help, it'd be greatly appreciated. It's the only function I can't get working on my phone. If you need more info, let me know. I'll be glad to help. I'm not online too often (I'm usually busy with school), but I'll be checking back whenever I get a chance.
Thanks in advance,
Ligor
Posted 07 March 2013 - 05:18 PM
Posted 07 March 2013 - 06:26 PM
Any suggestions are welcome!
Posted 21 March 2013 - 09:34 AM
All help is really welcome and very much appreciated!
Posted 18 October 2013 - 09:33 PM
I'm also on Cellcom with Razr Maxx, just decided to install CM 10.1 the other day. I was able to get the MMS working on my phone, at least while connected to 3G (Still not working on 4G). First, go into Settings > Wireless & Networks > More > Mobile Networks > Access Point Names. Add a new one. Following some into I found elsewhere, set the Name and APN to "Production", MMSC to "
", and MMS port to 80. Everything else should be able to stay at the default. I also deleted the APNs named "LTE - Verizon CBS" and "EHRPD - Verizon CBS", since they both contained Verizon specific settings. Just do a quick Airplane mode on/off or reboot just to make sure the settings take effect. I was able to send myself picture messages while connected to 3G. It stopped working when connected to 4G, so I'll have to do some more digging.
A little promising if you still have the phone, I see this is a older post though so maybe you got the S4 already.
