3G/4G switch?
Posted 06 March 2013 - 06:02 AM
Posted 06 March 2013 - 06:37 AM
It was built for the Thunderbolt but I have heard it works on other phone. Give it a go and let us know.
- zooyork0721 likes this
Posted 06 March 2013 - 12:47 PM
I have tried this app before. It works. I just don't want to have to manually go into settings and switch it myself. I just wish there was a more simple way to changing back and forth between 4G and 3G. Or maybe I'm not using the app correctly. But thank you.You can try this one:
Posted 06 March 2013 - 01:39 PM
Unfortunately this is a restriction of android in general. You can't directly change the network mode with a widget or app. The only way to do it is to make an app that makes a shortcut into settings or flash a ROM that has the toggle functionality.
Sent from my Nexus 4 using Tapatalk 2
Posted 16 March 2013 - 08:09 AM
Is there an app where I can just toggle on and off from 3G/4G just at the tap of a button?
I installed Nexesque rom resigned with java app. More information at this link:
hxxp://forum.xda-developers.com/showthread.php?t=739530
I use toogle 2g to switch manually in 3g/2g mode trough notification bar.
The toogle works very good. Also I don't love this android restriction.
#6 Guest_Xplorer4x4_*
Posted 16 March 2013 - 10:46 PM
This really only applies to stock.
