webtop on JB?
Posted 07 March 2013 - 11:39 AM
Thanks!
Posted 07 March 2013 - 11:51 AM
Sent from my Nexus 4 using Tapatalk 2
Posted 07 March 2013 - 12:01 PM
Posted 07 March 2013 - 12:24 PM
- todroid likes this
Posted 07 March 2013 - 01:29 PM
So then, on JB, is there any way to reclaim the webtop partition for storage if its not being utilized?They killed webtop support and updates. But if it's on the phone, its on the phone. JB doesn't include it or any newer iteration of it that's all.
Posted 04 April 2013 - 03:13 PM
I never did try it, as you need the exact byte start and end point for each partition to make the changes and to restore it if you fubar it. I was only able to find the size for the partitions, the start and end byte for just the 4 main partitions, but the partition order was such that I could not do any of what I wanted without at least 12 partition's start and end info (and specific ones at that!) I guess I could have done the math and figured it out...
