Motorola Lapdock 100
Posted 05 November 2011 - 08:59 PM
Unleash the computing power of your smartphone with Lapdock™ 100. Sleek and lightweight with a 10.1" screen, Lapdock 100 looks like a slim laptop but only comes to life when you dock your smartphone. Watch movies, edit documents, play games and browse the web with the latest Firefox browser. While docked, you can still text, use your mobile apps, and make and take calls.
- Badger1313 likes this
Posted 11 November 2011 - 03:59 PM
Posted 16 November 2011 - 07:11 AM
Posted 26 January 2012 - 01:42 PM
The Lapdock 500 has a 14" screen and a decent dock slot that holds the phone upright without the leash. I look at the 100 and think I'll have an issue using it on my lap with it on a tether
Has anyone bought the Lapdock 500? I am leaning towards it over the 100 and wanted to hear some opinions.
- Redalert likes this
Posted 01 March 2012 - 01:45 AM
Posted 01 March 2012 - 10:27 AM
I am trying to figure out if I should get a lapdock or just a keyboard for my Tablet. any thoughts?Got a 100. Had it for about 4 days now and I love it.
Posted 06 March 2012 - 12:12 AM
I would prefer a lapdock over a tablet + keyboard combo. Just because the lapdock is one piece that can be folded up vs. two pieces that need to be carried together.I am trying to figure out if I should get a lapdock or just a keyboard for my Tablet. any thoughts?
Posted 20 April 2012 - 09:41 AM
Posted 20 April 2012 - 09:47 AM
Posted 20 April 2012 - 12:21 PM
Where r they 60?
Posted 20 April 2012 - 01:34 PM
This one is for the ATRIX does it work for razr Max? Also what's the difference between the 100 & 500?
Posted 20 April 2012 - 01:44 PM
You have to mod the connector on the 100, but it works. The 500 has a larger screen among other things. It is also WAY more money.This one is for the ATRIX does it work for razr Max? Also what's the difference between the 100 & 500?
Posted 21 April 2012 - 05:05 AM
Posted 21 April 2012 - 05:37 AM
Posted 22 April 2012 - 05:32 PM
And damn, that Lapdock on ICS leak is flying! I love it!
Posted 25 April 2012 - 11:43 AM
I got Lapdock 500 for ~4 months now. I looked at Lapdock 100 but the keyboard was too small for my... small hands and it didn't have USB ports if I recall correctly. Got the 500 instead and never regretted. Front facing camera with a small LED for low light chatting, full size keyboard, USB to hook up a mouse and a LAN port (that i'm using right now) is what did it for me.
I had the same concerns with the 100. Once I get ICS, I will look into picking up the Lapdock 500 PRO. Thanks for the input.
Posted 10 January 2013 - 09:37 PM
Posted 11 January 2013 - 03:00 AM
Posted 11 January 2013 - 07:47 AM
Posted 13 January 2013 - 09:59 PM
