Anyone know how to get rid of the 6250 txts i get from verizon after an email or txt is received???
Big Red Txt's
smaher1081
, Mar 02 2012 12:25 PM
5 replies to this topic
Posted 02 March 2012 - 12:25 PM
Posted 02 March 2012 - 01:05 PM
All the freaking time. Annoying as heck
Posted 02 March 2012 - 02:32 PM
Have you tried removing your email and then re-adding it? If so and still not resolved then Log into your my Verizon acct and select the features of your line. Remove the backup assistant plus sync.
You may have to remove your email from your device and then re add afterwards. Issue resolved.
Posted 16 March 2012 - 12:07 AM
Thanks for the info, having same issue!
Posted 16 March 2012 - 11:15 AM
If you're running a custom ROM it's usually because VVM is active on your account but not on your phone. That or something similar
Posted 16 March 2012 - 03:13 PM
try logging into your verizon account and turning off the backup assistant plus as a feature. I was getting annoying texts from and unknown number and I am pretty sure that fixed it.
