I have a 32gb scan disc card and am having trouble keeps comming out of phone door keeps opening. Is anyone having this problem? I am wondering if it is the phone or the card. Thanks
SD card problem
wooddale
, Mar 12 2013 08:40 AM
4 replies to this topic
Posted 12 March 2013 - 08:40 AM
Posted 12 March 2013 - 09:32 AM
Before you click the tray with the sim card into place, place the sd card just inside the phone and then push it in with your fingernail until you hear it click into place.
Then put the sim card and tray back into the phone and you should be all set.
Posted 12 March 2013 - 09:38 AM
Thanks Pal Ill give it a try let you no.
Posted 12 March 2013 - 09:43 AM
Had to really push it in but it worked thanks.Before you click the tray with the sim card into place, place the sd card just inside the phone and then push it in with your fingernail until you hear it click into place.
Posted 12 March 2013 - 09:53 AM
No problem, glad you got it working
