Blur
Posted 04 March 2012 - 07:43 AM
Sent From My DROID RAZR MAXX
Posted 04 March 2012 - 08:01 AM
Posted 04 March 2012 - 08:37 AM
My RAZR Bleeds Awesomeness!!
Posted 04 March 2012 - 01:12 PM
Posted 04 March 2012 - 07:23 PM
The style of blur in general isn't bad, it just has WAY too much bloat, especially in the background services.
This is what I have been thinking as well. There is a smoothness of some sort with the blur on this phone that just seems to work. There is just too much extra crap that is not needed. The widgets, transitions, everything does have a nice look and feel to it.
Posted 04 March 2012 - 11:18 PM
Posted 09 March 2012 - 10:57 AM
There was nothing particularly wrong with MotoBlur for me as a launcher had it stood alone but I feel it is inferior to Go Launcher EX in terms of options, the sheer amount of bloatware (while not as bad as on the Rezound) was awful and most importantly the lack of a toggle menu in the pull down notification bar was the worst part. Coming from a Fascinate where even Touchwiz had toggles on the pull down and every single rom had toggles on the pull down it was a shock to me to find out that that not only the Razr/Maxx but also the Droid 1 and other Motorola phones did not have such a basic feature. Eclipse and Arctic and I assume all the roms for the Razr/Maxx do however so I had to flash out of stock.
I agree. Having the D1 before the Maxx I became accustomed to the drop down toggles. I miss them dearly but I'm hesitant to flash a ROM and have certain things not working. But then again as long as its GB based everything should work. I really wanted to wait for a stable ICS ROM to come out with everything working.
Posted 10 March 2012 - 04:05 PM
Posted 10 March 2012 - 06:29 PM
Almost as important, the 'fancy' animations applied to EVERYTHING is beyond annoying. Plus there is no way to turn them off, as far as I can tell the setting named as such doesn't do anything. They've got to drain battery and I find them extremely cheesey.
That's why I love me some Go Launcher EX. Super fast and smooth UI, tons of customization options, an insane amount of great widgets, and not only themes-a-plenty but an awesome tool to create your own themes.
Sent From Optimus Prime
:-D :-D
Posted 10 March 2012 - 07:03 PM
My main problem with blur is it seems almost just sloppily thrown together, for example if you put as many widgets as you could together on one screen they don't fit together.
I agree. I also use GO Launcher EX. It is the best IMO.
