[Theme] Orange Kream Sandwich For Axiom Aokp Ab9-B20 (4/8/12)
42 replies to this topic
#1 Guest_24v_*
Guest_24v_*
Posted 04 March 2012 - 04:26 PM
Thanks to DroidTh3ory, Dhacker, and Aokp devs for the rom.
Thanks to mopar57 for the inspiration and help.
Thanks to
for the code to put the weather in the statusbar.
MasturMods and this theme do not mix. If you are using MasturMods, reflash the rom before flashing this theme.
Instructions:
1)Make a backup in recovery
2)Download the zip that matches your current ROM and place it on your sd-ext
3)Reboot into recovery
4)Wipe Cache/Dalvik (The script in this theme will wipe for you, no need to wipe)
5)Choose zip from sd card
6)Select zip
7)Go Back and Reboot
8)Enjoy
Orange_Kream_Sandwich for AxiOM Aokp B20
md5
cafb2a8ff71d7556ea7d15665578ab3c
Posted ImagePosted ImagePosted Image
  • raijin32 and mudthestud23 like this
#2 thejakenixon
thejakenixon
    Mr. Nice Guy (who doesn't want to finish last)
  • 29 posts
  • Twitter:thejakenixon
  • Google+:Jake Nixon
  • LocationVandenberg AFB, CA
  • Current Device(s):Motorola Droid Razr
Posted 04 March 2012 - 05:17 PM
Wow this looks stunning, will it work for any device running b27? I'm currently using AB8 on the Razr.
#3 tyrthas
tyrthas
    CassDroid's Personal Stalker
  • 455 posts
  • Twitter:@tyrthas
  • Google+:Ron Becker
  • LocationMissouri
Posted 04 March 2012 - 05:19 PM
It should work for you. Have you flashed any mods like the 1%?
Sent from my AOKP AXI0M [R]
#4 Guest_24v_*
Guest_24v_*
Posted 04 March 2012 - 05:21 PM
This should work fine after the 1% btw. I flashed it on mine with no issue.
#5 Guest_24v_*
Guest_24v_*
Yes, give it a shot and report back.
#6 tyrthas
tyrthas
  • 455 posts
  • Twitter:@tyrthas
  • LocationMissouri
Posted 04 March 2012 - 05:23 PM
Alright, good to know. Wasn't sure how they'd like each other. Haha!
#7 Guest_24v_*
Guest_24v_*
Posted 04 March 2012 - 05:28 PM
The battery is screwy though. The 1% allows it in the settings, but the xmls are very limited for the battery that shows in the status bar. I fixed it and will put it into the next update.
Now if I could just figure out which xml controls the color of the clock in the status bar.
#8 tyrthas
tyrthas
  • 455 posts
  • Twitter:@tyrthas
  • LocationMissouri
Posted 04 March 2012 - 05:29 PM
That I don't know... but it can be changed to any color under ROM Controls in Settings.
#9 Guest_24v_*
Guest_24v_*
Posted 04 March 2012 - 05:33 PM
Well damn........
#10 tyrthas
tyrthas
  • 455 posts
  • Twitter:@tyrthas
  • LocationMissouri
Posted 04 March 2012 - 05:35 PM
Well damn........
I could use one of those right now lol!
#11 eraursls84
eraursls84
  • 97 posts
Posted 04 March 2012 - 07:03 PM
Well damn........
I'd just post up the hex code and let people know how to change it in the settings if they don't already know until you figure it out. Great job on getting all this working on ICS.
#12 Guest_24v_*
Guest_24v_*
Posted 04 March 2012 - 07:50 PM
If you are running the theme it puts the hex in there when you go to change it.
Pretty fancy.
If someone wants it, if is ff6c1c.
#13 Guest_24v_*
Guest_24v_*
Posted 05 March 2012 - 04:28 PM
So, I am going to try to follow Th3ory best I can with this theme as it seems there is some interest in it. I should have a new one up today to go with AB9.
#14 Guest_24v_*
Guest_24v_*
Posted 05 March 2012 - 07:31 PM
New one is up for AB9. Added a little more orange also.
#15 raijin32
raijin32
  • 277 posts
  • LocationMiami, FL
Posted 06 March 2012 - 06:39 PM
Once you're done with this one would you consider a Cyan theme for Axiom? That would look sweet against the black backgrounds. (No I won't ask for any lockscreen tweaks.) ;)
#16 Guest_24v_*
Guest_24v_*
Posted 06 March 2012 - 06:46 PM
ICS is cyan colored anyways isn't it?
#17 zero
zero
  • 86 posts
Posted 06 March 2012 - 06:50 PM
Looks like a sweet theme. This should work with future builds? color choices would be sweet. ; )
#18 raijin32
raijin32
  • 277 posts
  • LocationMiami, FL
Posted 06 March 2012 - 06:56 PM
Meh. Kinda blueish. I'm thinking something like this.
Sent from my DROID RAZR using Xparent Cyan Tapatalk
#19 Guest_24v_*
Guest_24v_*
Posted 06 March 2012 - 07:03 PM
I will do my best to keep it current with Th3ory's builds.
#20 Guest_24v_*
Guest_24v_*
Posted 06 March 2012 - 07:04 PM
I may do something like that, but it would be pretty far down the list since it is so similar to ICS.
Working on green right now. :)
