98.72.16 question
Posted 13 March 2013 - 08:16 AM
Posted 13 March 2013 - 08:32 AM
Posted 13 March 2013 - 08:37 AM
Posted 13 March 2013 - 08:55 AM
Posted 13 March 2013 - 09:31 AM
Posted 13 March 2013 - 10:48 AM
You have to do it from your stock ROM as opposed to using a ROM slot ..... boot into safestrap.... activate stock slot....wipe cache and dalvik cache.... reboot.... then try the OTA again....
Insert "uninstall safestrap" after the last reboot above. Even then it may fail and you'll need to use one of Matt's utilities.
Posted 13 March 2013 - 10:57 AM
Posted 13 March 2013 - 11:22 AM
Posted 13 March 2013 - 11:34 AM
i updated to 98.72.16 and have root but when i use ss3.11 i cant flash custom roms it will boot and go to safestrap screen saying wait for 10 sec but then flashes green and i used dl root checker and voodoo ota and all is good i just need to know how to get back to flashing my roms, again any help would be appreciated
You can't use the 98.72.8 roms on 98.72.16. You'll need to look at this for Matts compatibility tool.
- Memnoch73 likes this
Posted 13 March 2013 - 12:19 PM
