FM Radio
29 replies to this topic
#1 eanes_87
eanes_87
  • 113 posts
Posted 14 March 2013 - 05:20 PM
I know bionics are capable of playing FM radio, but can't find an app that allows me to do so. There was a custom rom (Icarus iirc) that had an FM radio app. Any way to get the radio going on stock ICS?
#2 Notc
Notc
  • 853 posts
Posted 14 March 2013 - 06:58 PM
#3 eanes_87
eanes_87
  • 113 posts
Posted 14 March 2013 - 07:05 PM
It says "not installed" after trying to install it. I found that earlier on Google. Can't get it to work.
#4 jdlowesracer
jdlowesracer
  • Twitter:jdlowesracer
  • Google+:jdlowesracer
  • LocationKansas
Posted 14 March 2013 - 10:23 PM
Ever since we were updated to ics the fm radio support died. I had to go to using Tuneinradio app to listen to the locals.
#5 johnlgalt
johnlgalt
    Antidisestablishmentarianist
  • 7,296 posts
  • Location3rd Rock
Posted 15 March 2013 - 08:16 AM
Uh, no, it did *NOT* die. I use it regularly.
I have two of them, one of them works for sure with ICS:
Try this one:
  • burnsd and irish711 like this
#6 eanes_87
eanes_87
  • 113 posts
Posted 15 March 2013 - 09:26 PM
Uh, not it did *NOT* die. I use it regularly.
Try this one:
Thank you, works like a charm!
  • johnlgalt likes this
#7 burnsd
burnsd
  • Current Device(s):Bionic
Posted 09 April 2013 - 05:53 AM
Try this one:
Works great, i'm on stock vzw ICS.
Thanks!
#8 johnlgalt
johnlgalt
  • 7,296 posts
  • Location3rd Rock
Posted 12 April 2013 - 08:52 PM
Glad it works for y'all. It's a lifesaver.
#9 kendog
kendog
  • 234 posts
  • LocationMillville, NJ
  • Current Device(s):droid bionic
Posted 14 April 2013 - 09:00 PM
Good radio app is called Spirit FM its way better than the stock moto one. Search in playstore or blackmart alpha
#10 kendog
kendog
  • 234 posts
Posted 14 April 2013 - 09:01 PM
Double post. Sorry
#11 csantarcangelo
csantarcangelo
  • 159 posts
Posted 15 April 2013 - 06:06 AM
Here's the app on the Play Store:
Just having fun with Android!
#12 johnlgalt
johnlgalt
  • 7,296 posts
  • Location3rd Rock
Posted 15 April 2013 - 09:00 AM
Funny that developer has stated that it only works on certain Moto devices but he didn't bother to limit the devices in the App Store.  It shows as 'compatible' for my Transformer Infinity.
#13 DrunkulaTX
DrunkulaTX
  • 124 posts
  • Twitter:drunkulatx
  • LocationDenton, TX
  • Current Device(s):HTC Droid DNA
Posted 15 April 2013 - 09:05 AM
This one used to work for me (the app above).  Fairly certain it did under ICS.  Regardless the non-working issue appears to be fairly widespread according to comments in the Play Store.  Oh well.  Didn't use it very much before but it would be nice to have working again.
HTC Droid DNA
Droid RAZR XT912 (retired)
#14 johnlgalt
johnlgalt
  • 7,296 posts
  • Location3rd Rock
Posted 16 April 2013 - 06:23 AM
Then go up a few posts -
  :D
#15 DrunkulaTX
DrunkulaTX
  • 124 posts
Posted 16 April 2013 - 08:09 AM
I already have and it still doesn't work.  Uninstalled. Reinstalled.  Doesn't work.  I even tried with the APK I had before.  Doesn't work.  Logcat didn't show me anything helpful.
EDIT:
Actually not sure if this is relevant but I did find this in the log.
Unable to start service Intent { act=com.motorola.android.fmradio.FMRADIO_SERVICE }: not found.
HTC Droid DNA
#16 johnlgalt
johnlgalt
  • 7,296 posts
  • Location3rd Rock
Posted 18 April 2013 - 11:11 AM
Are you running a custom ROMT?  b/c that file is in the stock software.
#17 dg5301
dg5301
  • 75 posts
Posted 18 April 2013 - 07:10 PM
Looks like neither of the free apps work with jb. I'll deal, but I always liked having the option to listen to sports talk, NPR, etc, without using data.
#18 kunaiboi
kunaiboi
  • 11 posts
  • LocationEast Texas, USA
  • Current Device(s):Motorola Droid Bionic, Kindle Fire
Posted 18 April 2013 - 09:05 PM
John, since you recently updated to JB, have you been able to get the radio to work?
#19 DrunkulaTX
DrunkulaTX
  • 124 posts
Posted 19 April 2013 - 04:52 AM
Running stock JB OTA, rooted.
HTC Droid DNA
#20 Notc
Notc
  • 853 posts
Posted 19 April 2013 - 06:46 AM
Hmm, according to John FMRadioService was one of the things removed from ICS to JB.  Don't know why they would just take it out entirely though.
