Cm 10.1 Help and useful info.
Posted 15 March 2013 - 03:05 PM
Alternative gapps
Camera and gallery force closing?
If you are getting force closes on the gallery and camera try deleting the data from both apps reboot and wipe dalvik/cache and they should work. I had the same problem until I followed those steps and everything is perfect.
Flash work around thanks to Kc69
Flashlight app works. Cam flash workaround for now.
- Meibs and Otakulad like this
Posted 15 March 2013 - 05:30 PM
Edit: I mean, what problems exist that these are fixing? Or do they add features?
Posted 15 March 2013 - 05:57 PM
Some people were having trouble with the other gapps. So I found these. I also had trouble with the CM gapps these are here in case anyone needs an alternative.Why the alternative Gapps?
Sent from my XT875 using Xparent ICS Tapatalk 2
Posted 15 March 2013 - 06:12 PM
via tapatalk on a rooted nook tablet
a girl has no sig
Posted 15 March 2013 - 06:40 PM
I haven't found it yet but I do have the actual photosphere camera from the nexus 4 system dump I will try it. If it works I'll post it.Think I might take the plunge and try this tomorrow. Is photosphere really in there?
- Staf_in_Wah likes this
Posted 16 March 2013 - 06:42 AM
- nakedtime likes this
Posted 16 March 2013 - 08:08 AM
I your right but never hurts to try. I'll post my results later.I thought photosphere can't work on a bionic because of the lack of gyroscope.
Posted 16 March 2013 - 08:10 AM
a girl has no sig
Posted 16 March 2013 - 08:20 AM
"Then it came after me, it got into my hand and it went bad, so I lopped it off at the wrist."
Posted 16 March 2013 - 10:36 AM
Fixed the link in the OP sorry about that.I am getting a 404 error saying that the file does not exist when I click on the link in the OP. The end of that sentence should be part of the link.
Posted 16 March 2013 - 11:24 AM
sent from my icy Bionic occasionally with a side of jellybeans
Posted 16 March 2013 - 11:40 AM
Kernel version you are looking for is 3.0.31 I believe its in the screenshot.OK how can I tell if I'm on kexec jb kernel with working camera? Currently running and loving liquid smooth...
Posted 16 March 2013 - 11:42 AM
Posted 16 March 2013 - 12:53 PM
Posted 16 March 2013 - 01:15 PM
I don't know about liquid. I can try to find out.Liquid smooth too?
Posted 16 March 2013 - 04:41 PM
a girl has no sig
Posted 16 March 2013 - 05:51 PM
its a bug hashcode is working onIt seems to be running well, but flash for camera apps doesn't seem to work.
Posted 16 March 2013 - 05:56 PM
Thanks!
a girl has no sig
Posted 17 March 2013 - 06:01 AM
Posted 17 March 2013 - 06:45 AM
Good idea!
OK, I'm going to ask a stupid question. Please be gentle, I'm a newbie! Yesterday was my first ROM.
When there is an update do I just flash it over the top of what is there or do I uninstall what I have and then flash the new version? I've not really gone into the functions and played around yet.
a girl has no sig
