Wacked Bootloader?
Posted 07 March 2012 - 02:21 AM
I seem to have fried my phone, but before I replace it, I thought a question or two might be a good idea.
Something went wrong with trying to install safestrap on my Eclipse ROM. In the past I have successfully used RSD to recover back to stock (maybe 4 times) for other various self inflicted wounds.
This time however, nothing happens, after about 35-40 minutes, RSD is still on process 1 of 18. Using the command line instructions, I was able to get back to stock but every time I boot it brings up AP Fastboot Mode (S) (Flash Failure) etc...
I can power off, hold down both volume buttons press power and bring up the Boot Mode Selection Menu where I select Normal Powerup. It boots fine and I am back to the stock .744.
I tried the OTA update to .748 and about 1/3 of the way through it gets stuck for a minute or 2 then reboots and gives me a message that the installation failed. No error codes, just installation failed.
I have tried to RSD again, but I always get the same result. It sees the phone, connects and then will not finish step 1 of 18. It just sits there doing nothing while the RSD progress arrows go back and forth. Every power-off brings me back to the FastBoot menu where I have to switch to Boot Selection Menu etc...
It seems to run fine on the stock .744, but I would like to update.
I have not tried rooting to see if that would help as it seems like my problem is more bootloader related.
Any advice before I scrap this one and get a new phone?
Thanks,
Doug M.
- dwmackay likes this
Posted 07 March 2012 - 06:46 AM
Greetings,
Thanks,
Doug M.
Try Matts utility as your method of fastbooting, also check your computer to make sure its not the reason for the rsd failures. fast boot takes a great deal of effort from your PC. I got rsd failures because of my comp.
Posted 07 March 2012 - 08:10 AM
Provide as many details as possible, we can help you get your phone back. There is no way (that I know of) to even touch your bootloader through normal flashing and the like.
:-D :-D
Posted 07 March 2012 - 10:07 AM
I know someone's going to post this so here:
Is you trying to fix your phone or not? I told you the same error happened with me and fastbooting fixed it. The problem is your method of fastbooting and your computer man.
Posted 07 March 2012 - 10:44 AM
Meanwhile, I called Verizon last night and they agreed to send me a new phone. I saw the warranty rant and could not agree more.
One of the few advantages of being older is that you have the ability to be a bit more charming and persuasive with the gentler sex. I was very candid with the agent at Verizon and after our brief troubleshooting, she decided to send me another phone free of charge even though I had clearly gone well outside the bounds of the warranty. I described at great length the process I went through of rooting, flashing etc… In addition to being mildly impressed with my technical acumen, she appreciated the apparently rare moment of self-incriminating honesty. The only other advantage of being a bit older is that had Verizon decided to not repair my phone as they would well be within their rights to do, I simply would have bought another one. Not fun, but not crippling either. It just makes being candid easier.
So now my phone is fixed and a new one is in route. I called Verizon again this morning and told them that I had somehow corrected the error and to cancel the shipment. Too late. It is on the way. So we agreed that I will simply refuse delivery and everyone will be happy. Verizon offered Customer Service above and beyond the call of duty and my phone is working again.
As a potential parting lesson from an old fart; "Let the truth be your friend". It is a philosophy that rarely disappoints.
This forum and the work shared here has provided me with many hours of entertainment as I break and then fix my shiny new Droid Razr. I made a donation to the board to express my thanks for all who serve our collective interests.
Thanks again for the assistance. I am almost certain to need it again…
Doug M.
Posted 07 March 2012 - 10:47 AM
Many thanks for the help. I tried Matts utility and it got me back in action.
Doug M.
Your welcome, hit the like button on my post if I helped you
