I seem to be stuck in recovery on the safe side and am not sure how to best proceed. Whenever I try to toggle safe system, it tries to restore data and then says "error occurred while restoring /data!" so I can't go back to the unsafe side.
I am using safestrap 2.11. I am on .215, running ICS with Arctic HD on the safe side. I want to get back to the unsafe side so that I can get the OTA update for jelly bean.
This morning, I was on the unsafe side just fine but hadn't wiped the data from the safe side. I went back over to wipe the data from the safe side so that I could come back to unsafe and uninstall safestrap, flash back to 211 stock with Matt's utility and get the OTA jellybean update. When I wipe the data, cache partition and davlik cache from the safe side and try to toggle safe system, I get the error. I am bit of a novice at this so I could use some help.
If I disable Safestrap from recovery, will I get stuck or is that what I should do?
I did make a backup on my computer of the rerware and the safestrap folder from my SD card but I can't get them back onto my sd card from my computer without flashing a ROM on the safe side, right?
Let me know if you have advice or would like more info to help.
Thanks!
Need Help - Restore data error
andymac111
, Mar 17 2013 07:48 AM
No replies to this topic
