Og Razr converted to Razr Maxx for less than $50
#1 Guest_BDH_*
Posted 17 March 2013 - 03:19 PM
As you'll be able to see in the pictures, there is definitely some bulging on my phone, that is, until I put a case on it. I see all these posts about converting to a Maxx and how it costs almost $200 to do it. Well I wasn't about to pay that much lol.
Now a little about what I did. I already had the Maxx battery which I got for free. However, you can buy just the battery, with the flex cable for less than $40. All you need to buy are the following items:
WHAT DO I NEED?
Maxx Battery
Toolkit (unless you already have the tools)
Thin but sturdy case
PRICES:
Maxx Battery - $36.95
Toolkit - $4.25
Case - $7.10
LINKS TO BUY:
Maxx Battery:
Toolkit:
Case:
WHAT'S OUR TOTAL?
$36.95
$ 4.25
$ 7.10
$48.30
So there you go, $48.30 to convert your OG RAZR to a MAXX. I used a different case other than the one mentioned above but the results will still be the same. I plan on posting a guide or video tutorial on how to do this sometime soon. In the meantime, here are my pics of my results.
Pictures with captions:
- cvhovey likes this
Posted 17 March 2013 - 03:50 PM
#3 Guest_BDH_*
Posted 17 March 2013 - 04:13 PM
Do you have to use that case?
You can use any case you want. You probably don't even need a case but I'm using one just in case.
Posted 17 March 2013 - 04:33 PM
Posted 17 March 2013 - 04:36 PM
Posted 17 March 2013 - 04:43 PM
#7 Guest_BDH_*
Posted 17 March 2013 - 04:51 PM
Can you use the backdoor the maxx uses?
I was reading the maxx backdoor helps make it not bulge out. But I'm not sure the case will fit right.
Well I didn't use a Maxx door and with the case you can't even tell the door doesn't fit.
Posted 18 March 2013 - 01:49 AM
how long have you been running it like this and is it stable?
- Einsteindks likes this
#9 Guest_BDH_*
Posted 18 March 2013 - 02:38 AM
Gary... I would advise against this.. as the battery is a flexible little thing.. and you are technically COMPRESSING the maxx battery.. causing over heating and damage to your device.. /me slaps gary..
Oh stop it lol. Been running it like this for weeks now. Perfectly fine, no overheating!
Posted 18 March 2013 - 02:42 AM
Posted 18 March 2013 - 02:59 AM
...not to mention putting undue pressure from behind on the digitizer. I did the other conversion. The extra cost is worth it. Would it make sense to shoe-horn a V8 into a stock sport-compact car without beefing up the brakes or drivetrain, and expect it to survive track day? I hope you do alright, but I wouldn't put much stock in that phone's durability. My recommendation is to get the other part/s to finish the job as best you can.
or somewhat less risky get a good case.. and leave the back off...
Posted 18 March 2013 - 05:26 AM
Posted 18 March 2013 - 05:33 AM
Posted 18 March 2013 - 05:39 AM
Posted 18 March 2013 - 05:52 AM
#16 Guest_BDH_*
Posted 18 March 2013 - 10:02 AM
- disturbed58 likes this
Posted 18 March 2013 - 12:25 PM
Google +: https://plus.google....816019544/posts
#18 Guest_BDH_*
Posted 18 March 2013 - 12:43 PM
It's only $100 on
Like I said, some people can't afford $100 but they can afford $50.
Posted 18 March 2013 - 12:48 PM
How much more are you getting out off the 3300? I'm seriously considering on getting one right now lol
#20 Guest_BDH_*
Posted 18 March 2013 - 04:17 PM
Compared to the OG RAZR I'm getting about double or a little more than double the battery life.
