Hello, I am going to preface this by saying: I do know what im doing, i just messed up...lol
I have a cdma Razr, and i was trying to flash the stock rooted .173 to it with bootstrap, and in the process, after i wiped/wiped devalik, i also formatted /system.
And after that, instead of going to "install from sd" like i SHOULD HAVE, i accidentally chose "reboot system".
Now my phone is stuck on AP fastboot
This is whats on screen:
AP Fastboot Flash Mode (S) (Boot Failure) = only thing i can figure is it wont boot because i formatted /system
0A.6C
To return to...blah blah blah
Battery Low
Cannot Program
Connect USB
Data Cable
Invalid CG OTV (CG System): Invalid SP Data
Invalid CG Version (CG: System)
Invalid CG OTV (CG: System)
/ Thats It
And also compunding the issue, as u can see, is my battery is low.
I have been trying to use BatMan's Razr Utility here:
But when i use option 1, it says Failure (Remote: Battery Low)
I left it on the charger overnight, and also did the sbf trick to get it to turn off and try to go into no power charge mode... or something like that... And my battery is still to low.
My main question is: how do i get it charging again to a sufficient level of juice to use the utility? Or is there a work-around so i can restore and re-flash and not mess up like an idiot...
I am stressed, i got this phone as a birthday present from the parents..
ANY help would be greatly appreciated.
Please Help! Razr Locked In Ap
bigtank27
, Mar 08 2012 03:50 PM
1 reply to this topic
Posted 08 March 2012 - 03:50 PM
Posted 08 March 2012 - 03:59 PM
As stated in all the threads describing how to use fast boot files, never do so with a low battery (most say 70%).
You're stuck unless you buy a programming cable, or I think there might be a thread were someone figured out how to do it but you're going to have to do some searching.
No one cares where this was sent from
:-D :-D
