I keep seeing this pop up and I'm wondering is there any kind of alternative to SQ lite to use to tether the Razr?? I seen the beta 9 and 11 downloads but a alternative to SQ lite sounds so much easier
Wifi Tether?
buckeyestilidie
, Mar 10 2012 10:06 PM
3 replies to this topic
Posted 10 March 2012 - 10:06 PM
Posted 11 March 2012 - 01:22 AM
I don't know what it uses, but
works without root.
RAZR No Longer. Currently running the LG G2 and HTC One (M8)
Time for Moto to update the line!
Posted 11 March 2012 - 06:12 AM
Sweet thanks man, do got any good battery savers??
Posted 11 March 2012 - 07:41 AM
Turn it off
I had problems with the Razr's battery. That's why I switched over to the Maxx. If you take your time and setup the Smart Actions, you should be able to push a little bit more out of it. Good luck!
