Need Help Can't Receive Messages
Posted 11 March 2012 - 04:08 AM
Hi guys,
I had updated my razr to 65.1.40.xt910.pshasiaretail via ota....after updating I can't receive text messages when I reboot the phone I get messages for 30mins.....but after I don't receive any messages...I don't use any 3rd party messaging apps......so any suggestions
Sent from my XT910 using Tapatalk
Posted 11 March 2012 - 08:48 PM
Sent from my XT910
Posted 12 March 2012 - 08:23 AM
Posted 22 March 2012 - 09:43 AM
Posted 10 April 2012 - 07:59 AM
Posted 11 April 2012 - 02:53 AM
Posted 11 April 2012 - 04:11 AM
Posted 13 April 2012 - 01:08 AM
Posted 15 April 2012 - 04:42 AM
Posted 05 May 2012 - 10:49 AM
Have downgraded the firmware to 2.3.5, but still the problem persists.
Motorola Customer Care, tells me to keep waiting indefinately for the ICS upgrade. Till then i cant use my phone, how annoying.
The folks at Motorola should be sued for such an attitude.
Posted 08 May 2012 - 09:07 AM
@farokh: are you the guy who has posted on the motorola owner forums as well? anyway i wanted to ask whether you got your phone downgraded from the service centre or using RSD?
Posted 20 May 2012 - 06:55 AM
Yes i am the one who had posted on the Motorola owner forum.
The service centre is a useless place, They told me that Motorola has stopped providing them with the 2.3.5 Update, they only have 2.3.6 update.
RSD will do you no good.
but i used the method prescribed by the razr guy on you tube, just google xt910 downgrade.
There is a link to download an eternity project flash tool.
I tried the European, French, Dutch, versions of 2.3.6 but still the same problem.
Infact even a downgrade to 2.3.5 doesn't solve my problem, so i dont think that it will do much good.
We should be suing Motorola for this....!
They wont even give me a replacement nor the money back....!
Posted 15 July 2012 - 10:07 PM
Posted 04 August 2012 - 11:17 AM
I am from Brazil and I am currently using ICS 4.0.4 (Vivo carrier). Claro carrier does not have this SMS issue, only Vivo and Tim (I have never tested with Oi carrier).
Just follow the steps below:
1. Open the message settings (default stock message).
2. Enable "Delivery Reports"
3. Disable "Auto-retrieve"
Boom! You're done!
Please tell me if that works!
Cheers!
Posted 11 August 2012 - 12:50 AM
I have been having the same issue since my phone was reset to factory settings (my charger was having issues and because it was under warranty I sent the charger and my phone to my service providers to fix it and they reset the phone).
I have update to ICS in the time that I have been having issue and the issues have not been resolved.
I initially called my service providers about the issue and they told me to try and find the 'sms-e' (?) menu, which could not be located and they told me to call motorola about the issue and get them to locate the menu so I can put in some code. I have yet to call motorola, but thought I'd see if anyone has been told to go through a similar process?
@ dehkun, I tried the settings you suggested and still had an issue
Posted 04 November 2012 - 01:55 PM
I tried to do like @
but then I made to recieve SMS from my home carrier, but I cant still recieve SMS's from other mobile carriers. I have ICS 4.04 and I tried to downgrade my android version, but problem stayed the same
I really dont know what to do... do you have ANY ideas? Did anyone made to fix this problem?
