Posted 23 March 2013 - 11:05 AM
Posted 23 March 2013 - 06:01 PM
Posted 23 March 2013 - 09:52 PM
What do you think?
Posted 23 March 2013 - 09:55 PM
Oh, and any ideas why phone.apk is such a butthead? i installed framework with the phone.apk and even with no edits it will not compile. so i tried it with systemUI and same result!! ThanksLet me just make sure I understand this. You don't want to flash a new SystemUI.apk, but want to change ur battery png? It's not possible. Battery pngs are located within SystemUI.apk. There is NO WAY to change the the battery icon without altering SystemUI.apk in SOME way. And if you want it to be 1%, you will need a modified services.jar as well. But fill me in a bit, I'm not quite understanding your request.
#5 Guest_BDH_*
Posted 24 March 2013 - 01:07 AM
Are you sure you have a JB compatible apktool? You should try this one, I've used it for virtually every apk with Jellybean and have never had an issue.
Posted 24 March 2013 - 07:11 AM
As far as the battery mod, besides what has been said, Timmy10shoes wrote a pretty cool battery mod. It backs up your original SystemUI and allows for multiple options for battery icons. I think he posted it in his blurry thread (Bionic). It should be easily adaptable for the RAZR.
- prosaschi likes this
Posted 24 March 2013 - 02:44 PM
Posted 04 April 2013 - 06:40 AM
Posted 11 April 2013 - 05:44 PM
Sent from my Droid RAZR MAXX Using Tapatalk 2
Posted 11 April 2013 - 05:58 PM
yes, have pro version, not what I had in mind. trebuchet, now thats cool. Thanks..ROM toolbox allows you to install custom battery icons without flashing the systemui.apk. the app is available in Google play
Posted 12 April 2013 - 06:57 AM
Posted 30 April 2013 - 12:06 AM
Posted 30 April 2013 - 05:49 AM
Could you post that link again for the battery MODS Timmy10shoes?
Posted 30 April 2013 - 03:37 PM
Never mind sir, found it........and I must say, these MODs are great!
Posted 30 April 2013 - 03:58 PM
My follow-up to this would be this. I do not think there is a way to use edify (flashable zip syntax) to decompile an apk that's already on the phone, edit it's folders, then recompile it. I could be way off base, but I really don't think it's possible. As far as ROM toolbox, I honestly haven't looked into what it's process is, but I do know that it doesn't work 100% of the time either.
Posted 30 April 2013 - 04:21 PM
Posted 30 April 2013 - 05:34 PM
I use a 7zip binary to replace only the battery icons to whatever rom your using UI.
Sent from Above
And it works pretty well...just like every flashable zip with his scripts!
Sent from my Speedlite AOKP Bionic
- timmy10shoes likes this
