Hello everyone I've been a member of this forum for a while I don't post much because I like to search, read, and figure stuff out on my own. But I have learnt so much from this forum so I just want to start out saying thank you to all the staff and devs I hope y'all enjoy it!
I've been working on this lockscreen for a while steadily tweeking it, this was a first time at a major xml edit and I learned a lot and failed a lot lol. But I finally got it to a point that I like, basically it is the aosp Jelly Bean lockscreen with the unlock circle moved up a tad bit so it doesn't cover up the verizon carrier label. I also added in the motorola sound toggle from the stock lockscreen. I have also set the haptic feedback on unlock to 0 I can't stand when it vibrates when I unlock my phone.
I want to thank djmcnz for this guide to add the reboot option
Disclaimer you are responsible for the stuff you do to your phone, I take no responsibility if you break it!
Installation:
Boot into Safestrap (v3.11 that's what I'm on will probably work on older versions)
You need to be on a stock based rom in a Rom Slot
Install Zip
Wipe cache/dalvik cache
Reboot
Enjoy!
Downloads:
Stock .16 Odex & Deodex Jelly Bean lockscreen only
Stock .16 Odex Jelly Bean lockscreen and Reboot in power menu
Stock .16 Deodex Jelly Bean lockscreen and Reboot in power menu
Back to Stock Undo zips:
Stock .16 Odex Back to Stock Lockscreen/Undo
Stock .16 Deodex Back to Stock Lockscreen/Undo
