Rooting RAZR Maxx on my MAC, HELP!
Posted 27 March 2013 - 02:02 PM
Linux/Mac-
-Extract .zip
-Open terminal and cd into the folder
-Run:
chmod +x razr_blade.sh
bash razr_blade.sh
I for the life of me can't get it to work. What does "cd into the folder" mean? I'm going to need a step-by-step. I have an intel based last gen iMAC. Thanks!
Posted 27 March 2013 - 02:10 PM
I'm trying to root my Maxx but I'm not being successful. The directions are short and only say:
Linux/Mac-
-Extract .zip
-Run:
bash razr_blade.sh
Its easier to walk someone thru in the chatroom.....
cd as in change directory same as windows.....
Open Terminal, type cd and a space, then drag the folder where the utility extracted into the terminal window and hit enter/return. you should now be in the folder/directory where you extracted all the files, and you should be able to see them. then do the chmod +x raz_blade.sh and then run it.
Posted 27 March 2013 - 02:41 PM
Posted 27 March 2013 - 02:43 PM
Worked like a charm! Thank you. I'm sure others will benefit from your information.
Sweet, glad something simple can work so easily
Posted 29 March 2013 - 07:48 PM
This is what I got on the last try:
Last login: Fri Mar 29 23:01:50 on ttys000
Gregsmac:~ mercado_gregory$ cd /Users/mercado_gregory/Downloads/razr_blade_mac-3
Gregsmac:razr_blade_mac-3 mercado_gregory$ dir
-bash: dir: command not found
Gregsmac:razr_blade_mac-3 mercado_gregory$ chmod+razr_blade.sh
-bash: chmod+razr_blade.sh: command not found
Gregsmac:razr_blade_mac-3 mercado_gregory$ chmod +razr_blade.sh
usage: chmod [-fhv] [-R [-H | -L | -P]] [-a | +a | =a [i][# [ n]]] mode|entry file ...
chmod [-fhv] [-R [-H | -L | -P]] [-E | -C | -N | -i | -I] file ...
Gregsmac:razr_blade_mac-3 mercado_gregory$ bash razr_blade.sh
[*] is connected via USB.
[*] Waiting for device...
[*] Device found.
[*] Phase one...
[*] Rebooting device...
[*] Phase two...
[*] 2. Select Get Started.
[*] 3. Select Battery Saver.
[*] 4. Select Save.
[*] 5. Press the Home button.
616 KB/s (3477 bytes in 0.005s)
link failed File exists
[*] Phase four...
3303 KB/s (91992 bytes in 0.027s)
3751 KB/s (1867568 bytes in 0.486s)
3811 KB/s (574184 bytes in 0.147s)
2387 KB/s (63838 bytes in 0.026s)
[*] Cleaning up...
/system/bin/sh: su: not found
[*] Rebooting...
[*] Exploit complete!
[*] Press any key to exit.
[*] Note: this wilGregsmac:razr_blade_mac-3 mercado_gregory$ Gregsmac:~ mercado_/mercado_gregory/Downloads/razr_blade_mac-3
-bash: Gregsmac:~: command not found
Gregsmac:razr_blade_mac-3 mercado_gregory$ Gregsmac:razr_blade_mac-3 mercado_gregory$ dir
-bash: Gregsmac:razr_blade_mac-3: command not found
Gregsmac:razr_blade_mac-3 mercado_gregory$ -bash: dir: command not found
-bash: -bash:: command not found
Gregsmac:razr_blade_mac-3 mercado_gregory$ Gregsmac:razr_blade_mac-3 mercado_gregory$ chmod+razr_blade.sh
Gregsmac:razr_blade_mac-3 mercado_gregory$ -bash: chmod+razr_blade.sh: command not found
Gregsmac:razr_blade_mac-3 mercado_gregory$ Gregsmac:razr_blade_mac-3 mercado_gregory$ chmod +razr_blade.sh
Gregsmac:razr_blade_mac-3 mercado_gregory$ usage:chmod [-fhv] [-R [-H | -L | -P]] [-a | +a | =a [i][# [ n]]] mode|entry file ...
-bash: -L: command not found
-bash: usage:chmod: command not found
-bash: -P]]: command not found
-bash: +a: command not found
-bash: =a: command not found
-bash: entry: command not found
Gregsmac:razr_blade_mac-3 mercado_gregory$ chmod [-fhv] [-R [-H | -L | -P]] [-E | -C | -N | -i | -I] file ...
-bash: -C: command not found
-bash: -N: command not found
-bash: -i: command not found
-bash: -I]: command not found
chmod: Invalid file mode: [-fhv]
Gregsmac:razr_blade_mac-3 mercado_gregory$ Gregsmac:razr_blade_mac-3 mercado_gregory$ bash razr_blade.sh
Gregsmac:razr_blade_mac-3 mercado_gregory$ * daemon not running. starting it now on port 5037 *
-bash: files: command not found
Gregsmac:razr_blade_mac-3 mercado_gregory$ * daemon started successfully *
Gregsmac:razr_blade_mac-3 mercado_gregory$ [*]
-bash: [*]: command not found
Gregsmac:razr_blade_mac-3 mercado_gregory$ [*] Razr Blade: Motorola Droid Razr 4.1 Root Exploit (Windows version)
-bash: syntax error near unexpected token `('
Gregsmac:razr_blade_mac-3 mercado_gregory$ [*] by Dan Rosenberg (@djrbliss)
Gregsmac:razr_blade_mac-3 mercado_gregory$ [*] Thanks to p3droid for assistance in testing.
Gregsmac:razr_blade_mac-3 mercado_gregory$ [*] Note: this wil
Posted 30 March 2013 - 05:59 AM
This is what I get for phase three:
It goes on to phase four and I end up with an unrooted device. I am attempting to root using a Macbook pro. Maybe this is the issue.
Posted 30 March 2013 - 06:56 AM
I still cannot root my Motorola Razr Maxx that has the jb update. I have followed the instructions and all progress until I get the following after phase three, which will not allow me to root. Not sure where to go from here.
I have rooted several phones using this on my mac...in your first post you made a bunch of mistakes, like not making the script executable. In the second post, I would say that your Smartactions have probably been updated so the exploit is failing.
You can try and troubleshoot the Smartactions by clearing data and cache for it, or you can get Matts JB utility which will restore your JB properly and then has Dans Razr Blade in it to root.
Posted 30 March 2013 - 09:18 AM
Posted 01 April 2013 - 08:02 AM
Where do I find Matts JB utility?
