Lockscreen Mod For Gummy Razr (Updated With Colored Icons)
kl0wn
, Mar 17 2012 03:30 PM
8 replies to this topic
Posted 17 March 2012 - 03:30 PM
So, if you ever tried AXI0M, and you used the Quad lockscreen, you probably liked it. Well on Gummy it just leaves those Stars '1' & '2'. Well these files will change that.
If you want to replace or switch the images from slot 1 to slot 2, or 2 to 1, change the file names below.
change
zzic_lockscreen_custom_one_normal.png --> zzic_lockscreen_custom_two_normal.png
zzic_lockscreen_custom_one_activated.png --> zzic_lockscreen_custom_two_activated.png
zzic_lockscreen_custom_two_normal.png --> zzic_lockscreen_custom_one_normal.png
zzic_lockscreen_custom_two_activated.png --> zzic_lockscreen_custom_one_activated.png
Also, if you do not want to use these icons, you can make your own custom icons also. The image size to do so is 162x162 (pixels).
WHITE
Download:
BLUE
Download:
Phone / MMS
Download:
MMS/Phone
Download:
MMS / GTakl
Download:
GTalk/MMS
Download:
GTalk/GMail
Download:
GMail/GVoice
Download:
GMail/GTalk
Download:
Instructions: These are a few different ways you can install the images inside the .zip files. This is just the way I personally used and it worked fine. IF people are having some problems using it this way, I will gladly make a ZipThemer file for these so you can use ZipThemer instead.
You'll need Ninjamorph, that is all.
1. Download.
2. Extract the Zip on your computer/phone and place the pictures on your sdcard
3. Open up Ninjamorph, click 'New Project', scroll down to system/framework/framework-res.apk and extract framework-res.apk
4. Open up the file browser of your choosing (RootExplorer for me), locate the pictuers on your sdcard, and move all of them to sdcard/AndroidThemes/workspace/framework-res and drop the files inside of the framework-res file.
5. Go back to Ninjamorph, click 'Finish Project' and choose framework-res. You will be prompt saying you are replacing, click Yes. You will then be asked to zipalign the file, click No.
6. Reboot the phone, and enjoy!
Thanks and credit:
White/Blue Icons - steve.messer84 (droidforums)
Colored - Brav1111 (RootzWiki)
change
WHITE
Download:
BLUE
Download:
Phone / MMS
Download:
MMS/Phone
Download:
MMS / GTakl
Download:
GTalk/MMS
Download:
GTalk/GMail
Download:
GMail/GVoice
Download:
GMail/GTalk
Download:
1. Download.
Thanks and credit:
- daddymikey1975 likes this
Posted 17 March 2012 - 03:44 PM
Glad you got the go ahead bud!
Great job getting this all sorted for the community.
Sent from my GUMMY RAZR
Posted 17 March 2012 - 04:54 PM
I'm still waiting on the other persons go ahead to use his icons. After he gives me the go ahead and I'll be posting up 7 more files with colored icons.
Posted 17 March 2012 - 05:02 PM
Nice! I'm pretty sure they'll be ok with it.
Posted 17 March 2012 - 08:05 PM
I would prefer a zip file to install from my sd card with CWM, if it's not a problem. LOOKS GOOD
Hey bub, I'm not finished with you yet..... SKNIT!!
Posted 18 March 2012 - 05:33 AM
I'm not going to make a flashable zip. I can make you a ZipThemer .zip which you end up flashing.
Posted 18 March 2012 - 06:12 AM
Thanks for posting this.
Gonna get rid of the stars this afternoon.
Posted 18 March 2012 - 07:30 AM
No problem, glad at least more than me found use for this, haha.
Posted 19 March 2012 - 12:49 PM
Updated the OP with more options, that are fully colored.
