My Razr HD is going to die...please help...
Posted 28 March 2013 - 09:16 AM
However, when I use this application to downgrade my HD from 4.1.2 to 4.0.4, somethings happened.
The CMD showed that it was successful but my HD just stuck in the bootloader mode.
Every time I turn on my HD, it came into the bootloader mode(it's bootloader mode, right?I'm not sure..) And no response. After a few minutes, it came back to the bootloader mode again. My HD just loop and loop.
I tried to type out the situation: (because I have no phone to use)
My HD shows that in a black wallpaper with some white words:
AP Fastboot Flash Mode (S)
10.98(*) (sla-5b608bc, 2012-11-13 20:26:57)
eMMC Info: Size 16GB
Device is UNLOCKED, Status Code:3
Battery OK
Transfer Mode:
USB Connected
Fastboot Reason: Flash Failure
usb connected
Actually, I didn't root my HD since I cannot find a way to root my 4.1.2 HD. I tried to connect with the RSD lite 6.0. It shows N/A about my HD...
I really hope that someone can help me with this situation...I just bought it 2days only...s
Thank so much
Posted 28 March 2013 - 09:43 AM
Did you try and use RSD Lite to go back upto 4.1.2? Thats what I did on mine. I tried to go back down to 4.1.1 and go an error, I just went back up to 4.1.2. Without unplugging my phone I cleared the 4.1.1 firmware from RSD lite and added the 4.1.2. and booted up. did all the sign in stuff.
Another stupid question. You deleted the getvar lines from the firmware.
Process I took for root.
turned phone on into fastboot and flashed the firmware
went through normal boot up process.
then I downloaded SuperSu Zip file from another site location, not sure if I can say where but it has three letters in the first name.
powered off phone, back into fastboot. flashed TWRP. follwed instructions, then without powering on phone, booted into twrp and flashed Supersu zip.
Posted 28 March 2013 - 10:20 AM
Posted 28 March 2013 - 04:55 PM
mine is froom Australia. And I think it is XT925...Need to know if Verizon DROID RAZR HD Developer Edition XT926 or RAZR HD XT925...
Posted 28 March 2013 - 05:07 PM
Thanks for your helping hand!!!I assume you have the Dev Edition if you unlocked the Bootloader.
Actually, I am now going to use RSD6.0 to flash back the 4.1.2 rom. But will it be okay if RSD cannot defy my HD? Because when I connect my HD with my computer, RSD shows N/A for all the info of my HD...
Posted 28 March 2013 - 07:39 PM
Posted 29 March 2013 - 02:34 AM
I'd assume what I did will work for yours also just use XT925 Firmware but not sure since I have the XT926 Dev Edition.
Posted 01 April 2013 - 07:19 AM
