Phone won't charge
Posted 29 March 2013 - 09:26 AM
Posted 29 March 2013 - 09:31 AM
Posted 29 March 2013 - 09:34 AM
- The Persuader likes this
Posted 29 March 2013 - 09:49 AM
It does not work in this manner either.Your charger also allows your phone to communicate with a computer (via USB). Does the cable work in that capacity?
how hard would that be since its rooted. do i just play dumb about that? Its not like it caused the issue, are faulty usb ports a common problem at all?If you just got it, I would consider getting a replacement...
Posted 29 March 2013 - 09:52 AM
You may want to google search confirm that, though.
Posted 29 March 2013 - 09:55 AM
Posted 29 March 2013 - 09:57 AM
I would try it, using Option 1 to reflash and Wipe. See how the battery is doing after that. If its not working, you will have removed root, so you can trade it in. If it is working re-root yourself. Do NOT let the play store update Smartactions....otherwise you will need to do Option 1 again.
hth
Posted 29 March 2013 - 10:04 AM
Posted 29 March 2013 - 10:07 AM
Posted 29 March 2013 - 10:09 AM
Posted 29 March 2013 - 10:11 AM
I did not know that. Thanks for that.Factory reset may help your battery issue, but it will not remove root.....
Posted 29 March 2013 - 12:59 PM
Rooting your phone has nothing to do with not charging your phone...It could be your USB Cable or your Phone...I agree with CMH...Replacement...its only going to get worse...
Its Bubba
Posted 29 March 2013 - 01:10 PM
im so low on battery charge now i dont think i could do that plus i can't plug it into the computer to do all that. i don't even do anything with the root. my phones not rommed or anything i was just starting to look into that stuff when this problem arose.
Hello trduff,
Juice Defender Utimate is Awesome...I will always get the Max out of my battery...Smartaction seems to cause me conflicts but that's my opinion...
Work both and others that your aware of...Let us know what you think is the better choice...
Its Bubba
Posted 29 March 2013 - 04:26 PM
Posted 01 April 2013 - 06:26 AM
