Sync battery between SafeStrap slot switching?
LDubs
, Mar 30 2013 02:22 PM
4 replies to this topic
Posted 30 March 2013 - 02:22 PM
so with all the cool JB roms floating around, I've been switching between slots a lot and noticed that my battery percentage doesn't sync - i.e. slot 2 battery will show 70% but when I switch into slot 1, it drops down to 40% and I soon need to recharge my battery.
Does anyone if there's a way to sync battery percentage between slots? Or reset it back after activating a new slot?
The price of liberty, and even of common humanity, is eternal vigilance. -- Aldous Huxley
Always do what is right. It will gratify half of mankind and astound the other. ---Mark Twain
Posted 30 March 2013 - 04:16 PM
I usually wipe battery stats with this. It isn't always 100% right but it does the job switching roms for me
Posted 30 March 2013 - 04:20 PM
So you flash that every time you switch between slots?
Posted 30 March 2013 - 06:56 PM
Yes
Posted 31 March 2013 - 04:52 PM
OK that seems to have worked ...nice nice, thanks!
- rocketsaucev2 likes this
