I have the car dock and am wondering if there is a way to get audio out through the USB or do you have to use a standard 3.5mm audio cable? My GS III car dock has a Y cable that is micro USB to USB/3.5mm audio out to my car stereo, does moto make something like this?
Audio out through USB
BladeRunner
, Apr 03 2013 02:51 AM
6 replies to this topic
Posted 03 April 2013 - 02:51 AM
Posted 03 April 2013 - 06:33 AM
Yes
Posted 03 April 2013 - 06:35 AM
Is there a special cable, something that needs to enabled, what?Yes
Posted 03 April 2013 - 06:39 AM
Haha sorry that wasn't very informative. I can't find just the cable, which is why I didn't put anything else....but Amazon sells the dock with the cable you're looking for
Again...not sure where you can buy just that cable though.
Posted 03 April 2013 - 07:54 AM
I found the cable at the Motorola website but the HD isn't listed as one of the compatible devices, hmmm
Posted 03 April 2013 - 09:09 AM
Wow I'm on a roll today...didn't even notice this was for HD. I would imagine it would still work, I would think this should work for any phone...
Posted 03 April 2013 - 09:48 AM
I am suspecting the HD doesn't do audio out through the micro usb. One would think the motorola made cable would be included with the motorola car dock if it did. The instructions for the dock says you need a 2.3mm audio cable to do audio through the car radio/speakers.
And by 2.3mm, I mean 3.5mm
