Thank you!
Posted 05 April 2013 - 11:29 AM
Thank you!
a girl has no sig
Posted 05 April 2013 - 12:25 PM
If you're using a content mgt system (wordpress, for instance) just the code for the widget will suffice--but the "fix" won't likely be as simple (if possible) because the actual code is actually stored on a site we can't actually get to.
I may be way off base or you may know all that already... The site hosting the widget may already have a fix for folks who want to use multiple widgets. (Perhaps embed one in an inframe widget if cms allows that?)
__________________sent from my bionic with dub_________________
Posted 05 April 2013 - 12:36 PM
What's the website URL? I think, though, you'll also want to share the Javascript and preferably pages code since it's sort of different from what user sees. If you're using a content mgt system (wordpress, for instance) just the code for the widget will suffice--but the "fix" won't likely be as simple (if possible) because the actual code is actually stored on a site we can't actually get to. I may be way off base or you may know all that already... The site hosting the widget may already have a fix for folks who want to use multiple widgets. (Perhaps embed one in an inframe widget if cms allows that?) Sent from my DROID BIONIC using Tapatalk 2
The widget was offered by the library software and the company hasn't been much help. I suspect that I'm the first one to try doing this.
This is the website address: n the menu at the top, I have different pages with the recently returned and new items widgets on them. Some are horizontal and some are vertical. It will double/triple/etc them either way if there are multiple on one page. It's my test website. I've not added it to the live version.
This is for the recently returned...
<div style="line-height:0px; height:0px; font-size:0pt;"></div> <div class="infoadvancedfLinkDiv" style="overflow: hidden;">
<script type="text/javascript" src="
</script>
<TABLE apollo_feed="recent_in:max=5:vertical:minimal=2:only_available=0">
<TBODY></TBODY></TABLE>
</div>
This is for the new items...
</script>
<TABLE apollo_feed="recent_added:days_back=10:max=5:vertical:minimal=1">
</div>
Thanks a bunch!
a girl has no sig
Posted 07 April 2013 - 09:04 PM
Cheers
- Staf_in_Wah likes this
Google +: https://plus.google....816019544/posts
Posted 08 April 2013 - 11:31 AM
You don't need to include the <script> twice. The reason it's doubling is because you have two apollo_feeds.js. I'd suggest try removing one of them, and preferably throw that <script> into your <head> tag, where it should be.
Cheers
Worked perfectly! Thank you
a girl has no sig
