Crazy Battery Issues On Razr Maxx
Posted 29 March 2012 - 04:45 AM
Posted 29 March 2012 - 05:58 AM
#3 Guest_DirtyDroidX_*
Posted 29 March 2012 - 07:02 AM
Sent from my Droid Razr using Tapatalk
Posted 29 March 2012 - 07:09 AM
Posted 29 March 2012 - 07:12 AM
Ps: "rild" accounts for 60% of my battery use. What is that?
#6 Guest_DirtyDroidX_*
Posted 29 March 2012 - 09:15 AM
Posted 29 March 2012 - 12:36 PM
my guess is a app that's doing it. Do a full wipe run stock for a day if you have same results you could have a bad battery .
Well i have a hard time believing its an app because i have been using the same apps from the beginning. After some google searches i found many people have had the same issue and it apparently can be solved by letting the battery run down almost all the way and then turning it off and charging until 100%. Gonna give that a try tonight. Thanks for the input. I do appreciate it
Posted 29 March 2012 - 01:33 PM
run stock with just the base stuff yiou need and see if theres any improvement
Posted 29 March 2012 - 03:40 PM
<br /><br />Yeah I've been using android for quite a while, aka not a noob, and I've tried all the usual tricks. Im not in a 4g area so i always turn it off. Thanks for the ideas though. Hoping that the suggestion i found earlier works out and I will report back.also make sure you go to accounts and turn off auto sync on features you dont need. make sure you arent just hanging on 4g.. and all that jazz.<br /><br />run stock with just the base stuff yiou need and see if theres any improvement
Edit: Yeesh i just read this back and it sounds like I'm a shlong. Didn't mean no harm
Posted 29 March 2012 - 05:16 PM
Posted 30 March 2012 - 04:26 AM
Was only able to charge it up to 70% because i needed to turn it on before bed ( alarm ). It seemed to help a bit and i hope to try again tonight.
Posted 31 March 2012 - 10:34 AM
I could not be more bummed. Only had this phone for a month and now its battery life is worse than my d1. I miss my d1
#13 Guest_24v_*
Posted 31 March 2012 - 10:39 AM
Start from stock with no extra apps and let it run for a full battery cycle, then report back. I would bet you have an app that is eating the battery. My Razr Maxx will go 16 hours with pretty decent usage before it even gets to 50%.
Posted 31 March 2012 - 11:14 AM
And I used to make it almost 3 days on a single charge if i really wanted to. So i definitely know its capabilities and would love to get back to that, its why I bought this phone.
#15 Guest_24v_*
Posted 31 March 2012 - 12:06 PM
I don't think the point that you "have been using the same apps" is valid. One of them could have updated, or maybe become corrupted somehow?
Until you try it without them, I would not rule them out.
Posted 31 March 2012 - 12:17 PM
#17 Guest_24v_*
Posted 31 March 2012 - 06:29 PM
Posted 01 April 2012 - 07:04 AM
Needless to say I'm running that but battery life has improved and I took your advice and am watching what I install app-wise closely. But as I said its improved quite a bit and I hope I'm on my way back to normal after a power cycle or two. Thanks again
Posted 02 April 2012 - 10:28 AM
Posted 02 April 2012 - 11:21 AM
