SafeStrap no soft keys on reboot
Posted 12 April 2013 - 01:32 PM
installed safestrap 3.12
Recovery state: Installed
Safe SystemL not active
i go to reboot phone and i get the " Safestrap is disabled" splash screen but there are NO softkey buttons..
nothing, just the disabled, boot in 10 seconds and that lil robot douche mocking me.
I have no idea whats going on.
any ideas?
Posted 12 April 2013 - 03:12 PM
probably a Brick use matts utility to go back to stockrunnin jb 4.1.1
any ideas?
Posted 12 April 2013 - 04:12 PM
Hello,
You're Already at Stock...Note, Is your Phone Rooted?
Tried a Factory Reset this will clean up the Garbage you have in your phone and will bring you back to Hard Stock..
After you Set-up your Phone...do a Nandroid or (Backup) Than...
Do some more Reading what you want to do with your Phone before you Venture to the ROM Slots in Safestrap
Its Bubba
Posted 12 April 2013 - 04:17 PM
I had the same problem once if he can't boot he's gonna have to use as fastboot to fix itHello,
Posted 12 April 2013 - 04:22 PM
Posted 12 April 2013 - 04:27 PM
Posted 12 April 2013 - 04:31 PM
did you try uninstalling and reinstalling your recovery and it should be 3.12its the right safestrap 4,12 for razr m. and the phone boots fine n runs except safestrap no options on boot
- neckchop likes this
Posted 12 April 2013 - 04:36 PM
- neckchop and brandon71 like this
Posted 12 April 2013 - 04:50 PM
Not even the Long press with the Power button?its the right safestrap 4,12 for razr m. and the phone boots fine n runs except safestrap no options on boot
Sent from my XT912 using Xparent Cyan Tapatalk 2
Posted 13 April 2013 - 06:29 AM
- shane1 and brandon71 like this
Posted 13 April 2013 - 06:35 AM
glad to hear you got it figured out hahaI am an idiot. Just wanna thank everyone for the help. I in fact did NOT install the correct safestrap, I was too cool to go back and look at the actual file i DL'd and go figure it was the razor HD.apk
Posted 13 April 2013 - 06:44 AM
Glad you got it working. And don't worry, it happens to the best of us.
- shane1 likes this
