This is probably going to be a very stupid thing i did, but i was trying to install the CM10 Working Camera ROM on XDA. I try to install it and it just hangs after Skipping the MD5 Verification. I have system mounted and zip verification unchecked. I feel like i'm missing something extremely obvious but i can't put my finger on it. Please help!
CM10 Installation Hangs on TWRP
johnpaul12
, Apr 15 2013 10:22 AM
3 replies to this topic
Posted 15 April 2013 - 10:22 AM
Posted 15 April 2013 - 10:58 AM
You do not have to mount system with any cm rooms. Just make a backup of your stock rom if possible then wipe everything except sd card. Install and it should work. If you have any backups of stock restore that first then wipe and install if the way I just said doesn't work Also make sure you are flashing the correct gapps after the rom.
Posted 15 April 2013 - 12:45 PM
I couldn't get the gapps file to install no problems with the ROM itself. I did go back to stock because of the screen wigging out with lines of random colors when you try to lock or unlock the screen. If they fix that bug they will have a winner.
Posted 15 April 2013 - 01:44 PM
Hmm. Its still hanging for me...
I did install CM10.1 beforehand but restored the boot.img before and went back to stock. Could that be the reason?
