Quick recover from bootloop
Posted 16 April 2013 - 01:44 PM
If you boot loop, hold volume up and down and power button. This forces a reboot. Quickly before you see Motorola m or boot loader warning hold volume up and down together. This boots you into twrp. And there you go. Saved your butt.
- neckchop, zooyork0721, PantherHeel93 and 3 others like this
Posted 17 April 2013 - 01:52 AM
Thanks for this
Posted 17 April 2013 - 02:13 AM
No problem. Would be very selfish to keep that to myself.
Posted 17 April 2013 - 02:15 AM
Not sure if it works from a brick. If someone does brick and tries it, let us know if it still works.
Posted 17 April 2013 - 02:43 PM
You can use this method anytime to get to stock recovery ie. Twrpi had an rsd lite flash failure and everytime it rebooted in fastboot mode saying flash failed, i found this method myself a few days ago (press volume up+down+power) it works and i wanted to apologize for not sharing like you did, flashing the recovery from the computer again made the reboot into fastboot go away.
Posted 17 April 2013 - 06:54 PM
I've used it on my M, when stuck at the M logo (twice so far) and once when I had fastboot flash fail. It simulates a battery pull, but will cause the phone to attempt a reboot. If you are bricked, you don't want to reboot, so you have to be quick (like you stated in your OP) and press them again to get into the Fastboot menu, or you can hold down the power button and the phone should power off all the way.You can use this method anytime to get to stock recovery ie. Twrp
- neckchop, shane1 and GracefuL00 like this
Posted 02 May 2013 - 12:37 PM
Posted 02 May 2013 - 12:41 PM
- RikRong likes this
Posted 29 June 2013 - 04:29 PM
sooo im stuck in a bootloop and my system is wiped on my twrp on help on how to side load a rom on razr hd
Posted 29 June 2013 - 07:27 PM
Pull your SD card out and use an adapter for the USB port on your computer. Then download a ROM and transfer to SD card. Re-insert into phone, boot into recovery and flash ROM.
- neckchop likes this
Posted 14 September 2013 - 10:34 AM
Thank you!!!! Just saved me rear end!
