phone won't charge unless powered off after JB update
Posted 17 April 2013 - 01:03 PM
Posted 17 April 2013 - 01:37 PM
- tom.etc likes this
Posted 17 April 2013 - 01:47 PM
I just installed the bionic update to JB, and now i can't get my phone to charge unless i turn it off. I calibrated the battery last night after it flashed but to no avail. Anyone one seen this? Is fxz to stock ICS an option so i can reupdate? Thanks in advance.
There is a way to reapply the update but you will lose root if you are rooted. Have you tried a factory data reset?
Posted 17 April 2013 - 03:08 PM
Posted 18 April 2013 - 10:52 AM
Nom, reapplying the update right now is nearly identical to using an FXZ in that it blows away your root backup that Voo Doo makes- rendering the phone unable to be rooted.
Posted 18 April 2013 - 11:42 AM
joyous. fortunate enough, this is what seems to have worked:
- wipe data
- let battery run all the way out
- charge with phone off all the way to 100%
now it seems to be charging as normal. Thanks for the help guys!
- tmyinc likes this
Posted 18 April 2013 - 12:48 PM
I had this happen as well- but all I did was power down, charge to 100% and then power back up... that seems to have solved it.
